problem of gearing, 1st and 2nd gear, Yaris 2008, 1.3 VVTi 64 kw
Hi everyone. Greetings from Slovenia !
I have a problem when I stop and I want to put in the 1st gear is not going or very difficult. When I then move and shift to the 2nd gear, it's always slightly stiff. It's very easy to do other gears. The clutch does not slip, but it's just a problem with the 1st and 2nd. I recently bought the Yaris 2008 year 1.3 VVTi 64 kw engine, 30,000 miles, previously driven by an old lady. What could be a clutch problem? Today we radiated an auxiliary clutch cylinder but the problem remained almost the same. the car was regularly serviced and the brake fluid changed recently. |
Drives: 2009 Yaris Base Sedan Join Date: Dec 2018
Try replacing the transmission gear oil.
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
And remember using a GL4 75w oil for the gearbox.
The original isnt that expensive at all. https://www.ato24.de/en/catalogsearc...q=+08885-81001
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 Last edited by stykerdk; 01-26-2019 at 07:16 AM. |
my mechanic says that 10 years old is a lot for still first gearbox coupling, so I'm thinking about changing new. But first we will replace the gearbox oil and the new gearbox wires, to see if will be better. Thx
tomorrow we will change the clutch kit. The new set is not that expensive, so I decided to change it, because the clutch is quite hard on the foot.
Please let us know how did the clutch change went and whether your clutch is now easier on foot too.
I have the same Yaris, same engine and the clutch is stiff and gerbox sometimes grinds when shifting from 1 to 2. AFAIK this is a known issue for Yaris and some people say the clutch change will not help while some other say it will. There are modified gear selector parts available that helped some people with this problem. My Yaris is now at 160,000 miles, clutch stiff AF but I do not know whether I want to pay 450 USD for the change here. It is too much considering how old this car is. |
This work takes 5 hours worked (I payed 80 € for my mechanic), on Toyota official servise they would charge me 370 € for this work, but the problem was when I realized that the clutch release bearing is not the same as the clutch release bearing on the car. When I checked in toyota online parts, I found that type A and type B of the thrust bearing have the same catalog number.
The mechanic has cleaned the soot that has accumulated around the axis of the clutch release bearing, so we put the old back, which was not in such a bad shape, although it is a basic rule that everything is replaced by a new one, once the clutch housing is opened. I was not happy about that. The clutch is now very soft on the pedal, but the problem of gear shifting from 1st to 2nd gear is improved just by 50%, which I think is due to the old release bearing. We also put the new gearbox oil from Mobile1, the old gearbox oil was already very dirty and liquid as water. I bought a new clutch kit from Luk, but it is interesting that the original clutch was also from Luk. On it was written: Toyota - Luk The new clutch set costs me 108 € + mechanic work 80 €. At toyota dealership serrvise that would be 650-700 € and 6 hours of work. |
What modified gear selector parts ? We solved the problem partially, but not completely.
The clutch is as soft on pedal, as the smooth clutch release bearing slides along its axis. It can be dirty with soot out of the disc assy clutch, which eventually wears. Last edited by cylaptor; 02-03-2019 at 04:12 AM. |
the clutch is now very soft. We gave a new clutch set of Luk. Interestingly, the origin of the clutch set was written by Luk - Toyota. The new kit contained only a different pushing bearing, ( I am not happy about that, we put the old one back, only ) because the variants A and B of different bearings are possible under the same catalog number. I paid € 108 for the material and the work of the mechanic for 5 hours was € 80.
We also changed a new gearbox oil because the old was very dirty and almost liquid as water. No it did not provide the right protection for the transmission. We cleaned the clutch housing and the clutch release bearing axis were greased with new grease. The old bearing (Type B) is inside the metal, and the type A (new one) has a plastic sliding core in the center, which is not the same, so we gave back the old one (it was still in a good condition), although it would be optimal to give a new one, but we did not have it at that time, and the gearbox has already been disassembled. Clutch release bearing : Type A, Type B......in the picture below. The same OEM part number. we were not able to know in advance what is currently on the vehicle Last edited by cylaptor; 02-03-2019 at 06:50 AM. Reason: picture |
the problem is still not solved. I examined it under the console of the gearbox, there is something to be set up at least. I will try to replace a longer 5mm push rod on the clutch's slave cylinder to better separate the clutch.
Just a good advice, start with changing the oil to original 75W GL4 as i adviced you to do.
You have put in a GL5 oil and that is against Toyotas recommendations. It has been discussed a lot on the danish Toyota forum, and there is also many who has tried other oils with poor result/shifting. And when they finally give up other oils and put the right oil in then they admit that solve the problem.
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 Last edited by stykerdk; 02-10-2019 at 09:28 AM. |
#12 | |
You Can read for your self Here with google translate.
http://toyotaextreme.dk/debatvisemne...0076&ForumID=1 2 People with bad shifting, and its solved with 75w Gl4 Oil .
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#14 |
interesting, there may be something wrong with oil. Thanks for the advice, I will certainly replace the original gear oil.
#15 | |
#16 |
This "original Toyota oil" is straight weight (not multi-viscosity) 75w GL4?
#17 | |
08885-81001 And it is also what is recommended for the car in the user manual. And you shall be really careful with GL5 oils, because some Toyota gearboxes has bronze bearings, and they can be corroded by some GL5 oils. They can seem really good at first, but when the damage first is done then you need a new gearbox.
#18 |
Mind of Toyota geographical transmission oil specification
Maybe one of those Toyota assembly robots doing the part-picking brought Norwegian transmissions to the line for some of our North American market Yari...we just need to find some of the right straight-weight 75w GL4.
| Idle issue on 2007 Yaris 1.3 | VinceSA | DIY / Maintenance / Service | 10 | 12-09-2020 11:43 AM |
| P0705: Yaris 2008 stuck in first gear in D position | eepp | DIY / Maintenance / Service | 3 | 01-22-2018 11:24 AM |
| 2007 Yaris Sedan Squeaky 2nd Gear | Omardavila1997 | DIY / Maintenance / Service | 2 | 08-24-2017 07:32 PM |
| When to go from 1st to 2nd to 3rd and so... | yaristhebest | Fuel Economy Forum | 30 | 01-15-2013 05:32 AM |
| Strugeling 1st gear!!?? | mhkritzinger | DIY / Maintenance / Service | 15 | 02-06-2010 10:25 AM |
