Old 08-23-2017, 11:31 PM   #1
Omardavila1997
Drives: Yaris Sedan 2007 Manual
Unhappy 2007 Yaris Sedan Squeaky 2nd Gear
I have a Squeaky 2nd Gear when shifting from 1st.
and really hard to shift into 5th gear and the reverse is this normal? it doesn't happen all the time but I find it weird and unsettling.
M/T
Last edited by Omardavila1997; 08-24-2017 at 01:12 AM. Reason: forgot to add what transmission i have
Omardavila1997 is offline   Reply With Quote
Old 08-24-2017, 06:20 PM   #2
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
I have a 2006 1.3l Yaris and i can confirm that reverse is hard to get into and makes noice when i put it in gear. Sometime i can't get into reverse so i let off the clutch, press it in again and that usually solves the problem. After that i get it in without clenching noice from the gears.
The shift from first to second is kinda hard, while i feel like the shift from second to third sucks in my particular car. I've never had any problems with 5th gear.
Sometimes i double clutch to third, because that makes it really smooth. So maybe if you double clutch to fifth gear, that makes it easier for you maybe.
In an ADAC test of a 2006 Yaris the tested car also had problems when shifting into reverse.
So i guess you just have to live with a bad reverse. I'm not sure if you can do something about the other gears tho. I haven't changed the transmission fluid yet, but i think that doesn't change much.
I think i kinda ruined my gearbox, by shifting too fast like an idiot in the past.
But hey a used gearbox is only like 250€ if it needs to be changed eventually.
DiCaprio is offline   Reply With Quote
Old 08-24-2017, 07:32 PM   #3
Omardavila1997
Gonna have to get a used gear box then or probably get my 5th fixed.
strangely my reverse went smoothly today same for 5th but I'm not gonna risk it and have someone look at it
Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise DevilzMafia DIY / Maintenance / Service 8 12-24-2012 08:05 AM
2007 Yaris Sedan Front Grille Stacieee Cosmetic Modifications (Exterior/Interior) 1 05-29-2012 09:48 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
