#55 | |
Do you wash your car at a self-serve spray bay? If you use a thinner product, it seems to attract less dirt/dust and sprays the dust off a little easier, leaving a cleaner, 'fresher' look. The thin stuff will leave a waxy layer even after you spray the wheels. The thicker stuff seems to turn the wheels a little browner as it captures and holds dust, brake dust etc. Some folks will deem this a little overboard, but once you get your routines down, it takes but minutes occasionally and your wheels will look great all the time.
#56 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Thanks a bunch, 06YarisRS. I called Rust Check (the stuff you mentioned), and they said they would send me some by the case. Finding Corrosion Block or LPS-3 is proving a tad difficult, but I did notice Corrosion Block is available via Amazon.
#57 |
Corrosion Block steel wheels steelie
I think my CB came straight from CB, Florida. I dislike anything spray-can if not a good reason for, so got 32 ounce plastic bottle which comes w/ little hand-spritz bottle.
After first apply it weeps out of the steelie weld line and collects dust on the rim. But wipes off the red powdercoat finish very easily and leaves great shine. (Then I just pretty much leave the wheels alone...along with the rest of the car, except windows.) |
#58 |
Thank you for that info, dogsridewith.
| Hubcap question 2009 Yaris Sedan- URGENT | mrs_yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-13-2016 02:21 PM |
| 09-12 Toyota Yaris Hatchback / Sedan 8 Spoke 15" Hubcap needed! | ard2014 | Willing to Buy by private party | 0 | 06-11-2014 04:16 PM |
| 08 hubcap | ryota | Willing to Buy by private party | 0 | 03-11-2013 09:08 AM |
| Hello! I need at least one hubcap for a 2009 Yaris Sedan | txprsn | Willing to Buy by private party | 2 | 05-15-2010 04:56 PM |
| WTB: Hubcap and Grille | LoadThis | Willing to Buy by private party | 9 | 11-05-2009 11:09 AM |
