#37 |
They look great! I agree with kimona, get some trim rings. There is also a center cap that would look stunning with the trim rings, though I was never able to find them for sale. I believe they are out there. I just didn't spend a lot of time looking for them.
#38 |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
HA, I was just about to say the black on black is nice but the trim rings may make it even classier. Good job.
#39 |
Yep, much better
#40 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Thank you, YWers. If I put on a set of trim rings, I'll post pics. Wish I could find those center caps you mentioned, 06YarisRS. I just hope my paint job lasts awhile.....don't want to be painting wheelies again anytime soon.
#41 | |
Your paint should last a good while, but it would be good to have a little touchup paint on hand. The areas that will be most affected is where your wheel weights attach and at the very lip of the rim. If you're not wanting to spray the entire rims with rustproofing, at least give those wheel weights a spray, then wipe off the excess. It will penetrate under the weights and protect where the paint gets scratched off.
#42 |
Thanks, 06YarisRS. I need all the tips I can get!
#43 |
![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
yea looks great
love the 2 door model |
#44 |
06YarisRS, what do you mean by rustproofing the entire rims? Would that entail spraying the rims with paint when a scratch occurs, etc? That sort of thing?
Thank you! |
#45 |
Thanks, justanotherdrunk!
#46 |
Not paint, just a light mist of rustproofing. After a few applications, a nice protective layer builds up. I usually degrease them in the spring and start over.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 03-29-2019 at 08:21 AM. |
#47 |
06YarisRS, do you have a recommendation for a rustproofing product I should use? I'm assuming it's a spray, right? Thanks.
#48 |
Toyota and Miata steelies are two pieces welded together. I oil the crack where they meet w/ Corrosion Block. The powder coater who did this Yaris' Miata rims in body color said rust first originates from this joint...that he shoots a bead of silver caulk on the various steelies that he paints silver.
The Yaris original 14" steelies got snow tires and Tercel plastic center caps that I paint w/ chrome rattle can. The Miata 14's get summer tread and have their mini chrome plated steel center caps w/ a Mazda symbol in the center. Last edited by dogsridewith; 03-28-2019 at 10:46 PM. |
#49 |
Since Rust Check isn't available in the USA, you might try a product like LPS-3 or Corrosion Block like dogsridewith mentioned.
#50 |
Thanks so much, guys.
#51 |
Wow that's a nice job. I've done mine a few years back as well. Now they are all rusted again lol
Sent from my CLT-L04 using Tapatalk |
#52 | |
#53 |
I'm definitely going to rustproof these rims. The last thing I want to do is do what I just did with these steelies anytime soon. Thank you for the info guys.
#54 |
Has anyone used Fluid-Film to rustproof their steelies? Thanks.
| Hubcap question 2009 Yaris Sedan- URGENT | mrs_yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-13-2016 03:21 PM |
| 09-12 Toyota Yaris Hatchback / Sedan 8 Spoke 15" Hubcap needed! | ard2014 | Willing to Buy by private party | 0 | 06-11-2014 05:16 PM |
| 08 hubcap | ryota | Willing to Buy by private party | 0 | 03-11-2013 10:08 AM |
| Hello! I need at least one hubcap for a 2009 Yaris Sedan | txprsn | Willing to Buy by private party | 2 | 05-15-2010 05:56 PM |
| WTB: Hubcap and Grille | LoadThis | Willing to Buy by private party | 9 | 11-05-2009 12:09 PM |
