![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Replacing intake manifold gasket
I changed the intake manifold gasket on my 2007 Yaris. It was relatively easy . I took some pics.
I drained the coolant from water pump lower hose.
I removed air hose between throttle body and filter box and disconnected vacuum lines and radiator cap pipe from throttle body. All bolts and clamps were 10mm
Wiring housing needs removed. Your can see the 12mm intake manifold bolts .
The spec for intake is 30nm. I tested it with a torque wrench before removal. It clicked and fasteners didn’t move . If the intake fastener moved spec would be lower. I got spec from English Haynes manual . I used a matco 8 inch long 1/4 drive ratchet . It worked but if I do it again I’m using my 11 inch long Armstrong 3/8. Thottle body wouldn’t come off. I moved intake forward skipped out old gasket and put new one in. Note old gasket was oily .
Put everything back together and used lisle funnel to add coolant. Run heater on full blast. Funnel helps burp air out . Note bubbles
Crappy rusty bent out of shape factory air box hose clamp
New stainless one I installed
![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
What was the reason/symptoms for changing the gasket? Just curious.
Intermittent misfire cylinder 1. Turned out to be fuel injector . Thought maybe vacuum leak in intake . The gasket was oily so it wasn’t a bad thing. Plus only cost $11 for a fel pro plus some Toyota coolant
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
nice, wish to see anyone can DIY to replace front sway bar bush
| Micro Image/Golden Eagle Intake Manifold Review | tmontague | Performance Modifications | 18 | 01-03-2017 09:24 PM |
| FS: Ported (for 1zz) OEM intake manifold | tmontague | Items for Sale by private party | 6 | 04-02-2016 12:25 AM |
| JB Weld stock intake manifold port w/ 1ZZ Throttle Body | tmontague | Performance Modifications | 2 | 10-07-2015 10:31 PM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 09:03 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
