![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
HELP! P0101 CEL
Anyone here have an injen intake on their yaris and having issues with p0101? surely i cant be the only one. im about ready to drive off a cliff with my car if i cant figure it out. HELP!
What is the inside diameter of the portion of the intake tube where the MAF is mounted? Common cause for throwing this code is people using an intake which is too large in diameter causing out of spec rate of airflow.
I believe it’s 2 inch diameter, I wish I can know anyone else who has this intake has the same issue or not
3 Yaris and counting..
I'm sure many people have had that intake. Problem is no one beyond the dozen or so active members comes here anymore.
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I was actually looking for an intake, as next performance gain.
![]() maybe not the Injen I take it.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| CEL afer oil pressure light | andysong | DIY / Maintenance / Service | 8 | 03-06-2020 03:57 PM |
| Injen intake, CEL P0101 | remcafee | Performance Modifications | 3 | 03-06-2020 03:52 PM |
| AFE Intake 2008 Yaris CEL Problem (Spacers) | LightDisc | Performance Modifications | 1 | 04-18-2018 07:26 AM |
| New aFe CAI = CEL with P0101 Error | randydid | Third Gen Yaris General Discussion | 10 | 01-16-2012 11:24 PM |
| AFE Intake cel | rihdrkc | Performance Modifications | 11 | 01-09-2012 04:23 PM |
