Old 07-24-2020, 10:32 PM   #1
mtshum
mtshum's Avatar
Drives: Echo RS
What’s this plug for?
Anyone know what’s this plug for?
File Type: jpeg 06280762-9E8C-41DE-B59B-130D1B50C2B3.jpeg (197.6 KB, 100 views)
mtshum is offline   Reply With Quote
Old 07-24-2020, 11:57 PM   #2
ex-x-fire
Looks like a drain plug for the differential portion of the automatic trans. Some Toyotas had check plugs too.
Old 07-25-2020, 12:07 AM   #3
mtshum
mtshum's Avatar
Drives: Echo RS
Do I have to open this drain plug too?
Old 07-25-2020, 01:07 AM   #4
ex-x-fire
I was searching for an answer, I haven't found one yet. I guess if you do drain it there, make sure theres atf behind that plug, when you fill it through the trans dipstick tube.
Old 07-30-2020, 12:03 AM   #5
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
Leave it alone unless you are ready to change your transmission fluid which can be tricky as the procedure has to do with oil temperature.
alanwagen is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 04:32 AM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 07:10 PM
Function of square plug near 12v. plug! RS-Yaris General Yaris / Vitz Discussion 2 11-22-2011 09:16 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 11:02 PM
