Old 08-19-2020, 11:19 AM   #235
lorne
Drives: 2007 1.3L AWD (auto) Vitz 5 dr
166,000 Kms ... a tad over 103,000 miles. I've only had it since about 160,000 Kms.
lorne is offline   Reply With Quote
Old 08-23-2020, 04:33 AM   #236
Kaktus
Kaktus's Avatar
Drives: 2003 Toyota Yaris
Just a mere 128000 miles so far in my ‘03 3-door hatchback, powered by the trusty yet peppy 1-litre engine. Still plenty of miles left in it!
Kaktus is offline   Reply With Quote
Old 08-24-2020, 01:24 PM   #237
Mister
Drives: Yaris T1
I am 184 000 KM on my Yaris.
Mister is offline   Reply With Quote
Old 08-26-2020, 12:22 PM   #238
lorne
Originally Posted by lawrenze04 View Post
At 143000 miles on 2012 Yaris Sedan. Dealership recommends me to replace the throttle body and flush the brake lines. What are your thoughts? Also they said that I have a timing cover leakage, which when I dont see any obvious leak. Anyone with the same experience?
CLEANING THROTTLE BODIES
In my humble experience, any crud on the throttle body can be cured with a spray bottle chemical. I've watched a licensed mechanic here in Japan pull the air-box conduit, and then spray the daylights out of the throttle body while reving the engine on the under-hood linkage. It cleared up the rough idle and stalling, and the vehicle was good to go until it went to automotive heaven! This is a pretty normal thing! There is a SPECIFIC chemical spray for this application!! I see this stuff in the wholesale, pro-tool and supplies shop I go to here in Japan.
FLUSHING BRAKE LINES
This should be a standard part of maintenance. In Japan, it's done every two years as common practice! DOT-3 brake fluid is hydroscopic.This means it absorbs moisture. The hydraulic system has to vent, and thus it is open to atmosphere. It eventually collects H2O in your fluid. Water will settle in your brake lines and in your hydraulic brake cylinders and callipers. I think you are really pushing your luck at 143,000 miles / 230,000 Kms!
Believe me — I've overhauled enough calliper bores, and either honed-out brake cylinders for new pistons and seals, or replaced them to know how they can rust and be ruined by contaminated brake fluid. You can work out the comparative cost of regularly flushing brake fluid as opposed to brake hydraulics overhauls. And I hate to think what might happen in the modern, pressure equalizer blocks — I never had to deal with those back in the days.
In Japan, the seasonal high humidity can be intense (not unlike many states in the USA). Here in Japan, as a matter of common policy, we flush brake fluid ever two years as part of the preparation for the mandatory licensing inspection. My wife and I ran a Honda for 23 years. We had one brake cylinder bore go bad in the 21st year. And not because of rust. The piston seal was weak. (Of course we replaced both cylinders.) The fluid had been flushed every two years, and the front callipers never needed service except for fresh pads.
If you are using DOT-4, it has a higher boiling point, but it is even MORE hydroscopic. So even more caution is advised. It must be great for track days, but I won't use it in my everyday transport.
And in case it has escaped you, water in the brake fluid detracts from stopping power.
TIMING COVER
As for the timing cover — I dunno, but if it means what I think it means, if there is no oil weeping around it, I cannot see the reason for servicing it with a new gasket or sealant. Perhaps the dealer knows that the gasket/seal does begin to weep or leak at about the milage your car has gone. Hell — leave it until it does leak and just keep an eye on it when you do your regular check on the dipstick.
(FWIW: I'm not a licensed mechanic, but years ago I serviced, repaired and overhauled stuff on motorcycles, cars and trucks for part of my living.)
Old 11-08-2020, 05:33 PM   #239
Lubbe 14
Drives: Totota Yaris T3 Spirit 5Dr Aut
121 000 Miles
195 000 Km
2006 1.3 Auto
2NZ-FE
Lubbe 14 is offline   Reply With Quote
Old 02-27-2022, 04:33 AM   #240
bairjo
Just hit 200,000 on my 2010 today. Runs like the day a i purchased it new and still has no rattles etc.
bairjo is offline   Reply With Quote
Old 04-03-2022, 10:27 AM   #241
NoEscapeSedan
Drives: 2008 Sedan
188,888miles here on my 2008 Yaris Sedan. The water cooler went out and was replaced under warranty. Around 160k miles the clutch went out I had it replaced it drives like new. I look forward to joining the 200k miles club soon.
NoEscapeSedan is offline   Reply With Quote
Old 04-08-2022, 08:05 PM   #242
skelly410
Drives: 2010 yaris 4 door hatchback
Just turned 350000 tonight! 2010 yaris 4 door hatch with 5 speed. Still has the original factory clutch! The only parts replaced have been 3 wheel bearings (the passenger side rear is still original), 1 alternator, 1 cv shaft on drivers side, and of course brake rotors and pads and tires. If you have 100000 on yours it's not even broken in yet if u take care of it. These things have to be made with alien technology..... They are almost indestructible. It also doesn't burn a drop of oil between changes every 3500 miles. Shooting for half a mil! And yes..... Original water pump too!!
skelly410 is offline   Reply With Quote
Old 04-13-2022, 03:28 PM   #243
libraryelf
Drives: 2008 Yaris white
Milage for Yarrie 2022
I put all those miles on myself. I drove cross country once. Go Yarrie 2008. She has a leak somewhere letting in water in the trunk, but two washed clothes at a time take care of that.
libraryelf is offline   Reply With Quote
Old 05-09-2022, 04:54 PM   #244
rodrigogar
Drives: 07 Yaris Sedan S
Originally Posted by rodrigogar View Post
My 07 Yaris Sedan has about 126k miles on it, there was a grind sometimes during shifting and had the tranmission replace for a small deductible because when I bought the car it came with a lifetime warranty for the power train.
Needless to say, I don't think I will be getting rid of it anytime soon...
Hello everyone, wanted to update my old comment.
We are now in 2022 with 203,000 thousand miles :D. I have been a lurker but this forum has been a resource for a lot of troubleshooting of my car. So thank you for that.
As I have had the car since 2007 and done some work on it I may start posting a bit more when I work on the car.
rodrigogar is offline   Reply With Quote
Old 05-11-2022, 02:09 PM   #245
gilsaluki
Drives: 2007 Toyota Yaris 3DR
225,000. Wife ran smack dab into a parked truck's trailer hitch going about 35MPH. I thought it'd be totaled. I bought two new bumper brackets, repaired a gapping hole in the bumper cover, painted it. Almost like new again. No mechanical failures to date.
gilsaluki is offline   Reply With Quote
Old 05-17-2022, 02:00 AM   #246
sh0rtlife
currently sitting in the mid 160k(kilometers) so probably over 100,000 ish, only annoying rattle is a common one, paints still good EXCEPT the roof where wifes surfboards would drip salt...but its just clear coat, no major repairs dents or otherwise couple penny size dings and some hood chips..the rear leaks SOMEWHERE when it POURS and its only very little, on either side under the side cargo trays at the very trunk end....i know its not the hatch seal as i modded the latch so it shuts a lil tigher a long time ago when i thought it was letting alot of water in
still tight n crisp everywhere...laugh at the low mileage all you like but its been a daily driver all its life.and ALWAYS outside...wife bought it new in BC living in victoria..so on an island milage doesnt rack up all that fast, in the past 7 or so years weve doubled the milage since being stateside
only real thing showing wear is the drivers seat side bolster(left hip)..not a speck of rust and in all honest the paints so nice i dont see a repaint any time in the forseable future...aside from likely the roof between the drip rails
aside from tire and brakes(another set of both before summers out) nothings really been replaced, heck the original headlight bulbs were swaped for HIDs a few months back, and i swapped out the driver door seal due to "yellowing"..headlights have to get swapped out this year tho as the "crazing" is far to bad to polish out...its on the inside of the lensing
Old 05-19-2022, 04:37 PM   #247
billfires
Drives: 2010 3dr LB
Just turned 200,000 miles on my 2010 2 door hatchback with 5 speed manual. Only non wear items replaced were cam position sensor and the alternator. Best and most reliable vehicle I have owned. Bill C
billfires is offline   Reply With Quote
Old 06-07-2022, 08:35 PM   #248
slayazu
Drives: 08 Yaris Base 3dr
178xxx as of now. Excited to get to 200,000 miles. ^also named Bill
slayazu is offline   Reply With Quote
Old 03-23-2023, 03:45 PM   #249
JustFPV
Drives: 2006 Yaris 2dr hb manual
I'm at 135k (218k km's) now but only had the car for 2 years. I just did a bunch of work to it so I expect it run fine without any major work for another 100k. I'm constantly amazed at how a 17 year old car can still be a strong daily and run so well.
JustFPV is offline   Reply With Quote
Old 07-06-2023, 10:53 PM   #250
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
2001 Toyota Echo with just a couple miles
(100% totally legit not a fuck up reprogramming the mileage)
Cletus Garfunkle is offline   Reply With Quote
Old 03-22-2024, 03:03 AM   #251
libraryelf
I now have 120,000 miles on my 2008 Yaris. She has a dent from a recent hit, and a leak somewhere in the back, which tape is helping with. I'm trying to get a picture of my mileage, but for some reason, it is hard to get the picture to post here. [IMG]mileage3212024[/IMG]
Old 03-22-2024, 08:20 PM   #252
Billiam
Drives: '10 White Yaris 4D LB
100k is nothing on a Yaris. Our '10 (which is now my 16 year old's) is at 170k
If you want to enjoy your car, stay off of the internet.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 12:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
