Old 10-21-2020, 08:52 AM   #1
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
NGK Non iridium spark plugs for 2010 yaris
Search function isn't friendly to me today. Anybody have the part number for NGK non iridium spark plugs for my 2010 yaris?. TIA
frog13 is offline   Reply With Quote
Old 10-21-2020, 10:17 AM   #2
RPH
Drives: Toyota Yaris XP9 1.3 VVT-i
I just bought these NGK for my Toyota Yaris mk2 from 2006
Denso should be these: K16R-U11
NGK: BKR5EY-11
Probably these then: https://www.ngk.com/ngk-7390-bkr5ey-v-power-spark-plug
RPH is offline   Reply With Quote
Old 10-21-2020, 03:04 PM   #3
frog13
Tw200--excellent!
I finally found the standard NGK plug.....BKR5ES-11. The 11 is for heat range.......I believe. There's also a second number associated with the aforementioned......2382. It's underneath. Thank you for responding. Your Denso # K16R-U11 is accurate too.
Old 10-21-2020, 11:16 PM   #4
komichal
What engine do you have? My 2SZFE uses BKR5EYA. But I guess this engine is not common outside Europe.
Old 10-22-2020, 03:00 AM   #5
RPH
When I look that one up I get results it's for Hyundai and Kia.
2SZFE motor uses BKR5EYA indeed.
Old 10-30-2020, 09:43 AM   #6
frog13
Tw200--excellent!
Engine.......not being a jerk by saying this , but, it's the USA engine......not sure of the family engine number.....1NZ-FE........could be correct?
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
spark plugs walt101786 DIY / Maintenance / Service 0 09-24-2011 05:25 AM
How Do These Spark Plugs Look? Kaotic Lazagna DIY / Maintenance / Service 12 06-21-2011 04:17 PM
