#127 |
![]() Drives: Yaris 2008 Sedan Join Date: Apr 2012
I think I'm going to pick up a voltage detector from Lowes tonight. One more question: will I be able to tell which wire coming from the reverse light is positive (versus negative) simply using an analog voltage detector?
#128 | |
#130 |
![]() Drives: 2008 BLACK YARIS Join Date: Sep 2017
can you please tell me where to take off a 12 volt feed (when the high beam is activated) for my driving lights relay.
Little or no voltage or current required, just power ONLY when high beam is activated. Thanking you in advance. |
#131 |
![]() Drives: 2009 Yaris hatchback Join Date: Nov 2017
People who can share wire schematic/diagram for master windows switch. Look to hookup original master switch to aftermarket power window kit want use original switch instead of one from kit to have auto option.
2009 Yaris hatchback Sent from my iPhone using Tapatalk |
#132 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The headlights are earthed to turn on, with permanent 12v power. The simple way is to wire the relay coil across the 2 parallel contacts on the headlight socket.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#133 |
Drives: yaris Join Date: Feb 2021
Hi,
I have a 2007 yaris hatchback with no daytime running lights. I bought an aftermarket LED DRL bar, can anyone tell me how to wire it so it switches on after the car starts? Thanks |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
