Old 09-25-2017, 07:35 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Replaced Downstream O2 Sensor
I've had a check engine light on since I bought the car. According to Torque Pro OBD2, I had zero volts on the bank 1 sensor 2. So, I replaced the sensor today and was disappointed that it still read 0 volts while idling in my driveway, however the MIL did not return. But I went for a drive and now it works. Getting a good sweep from 0.1 to 0.9 volts and air fuel ratios, commanded and measured, are perfectly in sync. I found the answer on another Toyota model car/truck forum.
Anyone want to guess why it didn't appear to work at first?
Old 09-25-2017, 10:05 PM   #2
SirDigby
Drives: 2007 yaris 3 door
maybe when it was in open loop it had not sent voltage to sensor yet. (?)
Old 09-25-2017, 10:12 PM   #3
06YarisRS
It may be. But, I don't really understand the concept of open loop even after reading a couple of explanations. My pea brain was incapable of grasping the idea. But, it sounds like you are on the right track in that it did not show a voltage until a certain condition was met. What condition do you think that was? It is different than my Kia's sensors as they will start to show fluctuating voltages from the 02 sensors as soon as it's started.
I don't know much about vehicle electronics.
Wish me luck as I paid $18.00 USD on eBay for this sensor. It's a cheap knockoff, but seems to work - so far anyway.
Old 09-25-2017, 10:41 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The sensor needs to heat up before it works. O2 sensors create their own voltage, so what you're reading isn't anything sent from the computer. It only reads what the sensor sends it.
Old 09-25-2017, 10:59 PM   #5
06YarisRS
Yes! I read that it has to reach, I believe, 600F before it sends voltage. Thanks for playing, both of you!
Old 03-01-2021, 06:53 PM   #6
Neinris
Drives: 08 Yaris 3 Door Hatchback
O2 Sensor downstream connection location?
I have multiple faults and I think it’s my downstream O2 sensor that’s most likely the culprit. I went underneath the car, but the connection leads inside the cabin. Where is it exactly located?
Neinris is offline   Reply With Quote
Old 03-01-2021, 10:52 PM   #7
Neinris
Thanks Adam
Just want to share the youtube video you sent me:
https://www.youtube.com/watch?v=yT5Wgs1b6wg
Old 03-02-2021, 07:06 AM   #8
06YarisRS
Glad it helped you!
Old 03-09-2021, 11:03 PM   #9
remcafee
start saving for an oem sensor, i replace tons of aftermarket sensors on customer cars coming to the dealer complaining another shop fixed their car a month ago and it has the same error codes back on again
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
Upper O2 sensor replaced but did not fix the problem Hard_Yaris DIY / Maintenance / Service 9 04-10-2013 10:22 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
