![]() Drives: Toyota Yaris Join Date: Oct 2021
Wiring to new tow bar
Hello,
I am new to this forum and this is my first post so not completely sure this is the right place for the topic. Anyway here goes. I have a UK Yaris 1300cc built 2013 which has can bus wiring. I am in the process of fitting a tow bar with the intention of towing a small trailer and dingy. Fitting the actual tow bar is straightforward but despite lots of research and removing panels, seats etc I have been unable to find any suitable place to link in the wiring from the tow bar 7 pin plug. Is there anybody around who can point me in the right? Thanks for reading this. |
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
This is not exactly what you are looking for but it has enough information for you to figure out the answers. It's all I could find.
https://www.youtube.com/watch?v=f4icvF_G3ts |
Tow bar
Thank you so much for the link.
This is exactly what I was searching for but didn’t think to search internationally. Thanks again and very best wishes. Gregg |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I had my tow bar and wiring professionally installed. The wiring includes a module that taps power from a switched fuse in the under dash fuse panel to repeat the lights to the trailer. I presume this is to avoid changing the load on the blinkers, possibly altering the flash rate. It also means I need to turn the ignition on to check the trailer lights.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Glad I was of some help. I'm appreciative of your response as that doesn't happen very often in my experience which has made me reluctant to stick my 2cs in sometimes.
| 2010 HB tow bar for push bikes | amanda_84 | Australia | 0 | 05-10-2011 01:01 AM |
| Tow bar for Yaris | dekers | General Yaris / Vitz Discussion | 8 | 10-28-2009 06:28 AM |
| Tow Bar for Yaris. | pismo61 | General Yaris / Vitz Discussion | 19 | 08-26-2009 01:02 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 08:20 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
