![]() Drives: Yaris 2008 Join Date: Jan 2022
Lug Nut / Wheel Fitment Advice
I am trying to install Circuit Performance 15 x 6.5 alloys on my 2008 Hatchback. They didn't fit because of the center bore. I ordered aluminum Hub Centric Rings 73.1mm outer and 54.1mm inner. Is that all I will need now for a snug fit? Or will they also need aftermarket lug nuts? I have the stock lug nuts that are used for the steelies at the moment and would like to use those if possible. Thanks for the advice.
Update: The wheel manufacturer recommended me some specific ones that I just ordered. Will update again when I try to install them.
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Get aftermarket lug nuts.
Tuner lug nuts more specifically.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
typicaly speaking steel wheel nuts will useualy have a different taper to mag nuts, but its not always the case and can vary wheel to wheel, if the wheels have a steel cone in them they are often made to use a steel wheel nut, if they are raw coned aluminum then they useualy need a wide flange mag nut
but everything changes wheel to wheel manufacturer to manufacturer...more often than not you cant even take their word for it and need to check once you have the wheels in hand |
| Tags |
| centric ring, hub bore, lug nuts |
| Wheel Fitment Database | DuckinOut | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 11-13-2008 02:07 PM |
| Wheel Advice | caveatipse | Cosmetic Modifications (Exterior/Interior) | 8 | 09-19-2007 02:39 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
| lug nut spacing | thatboyjer | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 34 | 07-13-2007 12:45 PM |
| Wheel fitment? | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-26-2007 12:18 PM |
