Old 06-27-2022, 04:39 AM   #91
almamater
Drives: Yaris 2006 - 1.0
Well, my Yaris 2006 had the same issue 1 month ago, yesterday i decided to do the procedure mentioned here, thanks to Sven337 !!
All worked Now, i decided not to remove the transistors, i just added the MP1584EN, and in this way, the dim functionality continues to work..
If anyone needs pictures i can post them, i took some.
Thanks!
almamater is offline   Reply With Quote
Old 09-26-2022, 05:58 AM   #92
brugal67
Drives: yarish
could you send me the photos of the modification?
brugal67 is offline   Reply With Quote
Old 03-14-2023, 01:55 PM   #93
Marafado
Drives: Toyota Yaris
Thanks!
Hello.
Another one with the same problem.
Thanks to sven337's posts, I'll try to follow his procedures as well.
In your case, you decided not to remove the transistors. You say that this way the variable brightness functionality remained functional.
Can you confirm that everything is back to normal after the repair and no more problems have appeared?
I'm thinking of a more complex repair, but just in case it's justified!
Thanks
Marafado is offline   Reply With Quote
Old 05-18-2023, 11:59 AM   #94
Marafado
Here is the solution I implemented.
Old 02-17-2025, 06:15 PM   #95
bubinio
Drives: Yaris 1,3 2007
Hi mate! Can you give more details about the module?
bubinio is offline   Reply With Quote
Old 12-01-2025, 12:34 PM   #96
FabioB
Drives: Yaris II Serie
C'è qualcuno che potrebbe dirmi se ho dissaldato i giusti cluster? Grazie
https://ibb.co/PvPWccxF
FabioB is offline   Reply With Quote
Old 12-08-2025, 08:48 AM   #97
jacki22
Drives: toyota yaris
Please, I'm looking for the wiring diagram for the connector.
jacki22 is offline   Reply With Quote
Old 03-17-2026, 07:07 PM   #98
magicyaris
Drives: toyota yaris 2006
Muchisimas gracias a sven337 por la información y a adsb por las imágenes proporcionadas sois unos putos Top Globales y unos máquinas.
Gracias a este foro y toda la información que hay aquí intentaré arreglar la pantalla del yaris y sino lo consigo ha sido un placer enloquecer junto a ustedes
magicyaris is offline   Reply With Quote
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 08:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 04:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 09:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 06:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-09-2009 11:33 PM
