Old 02-25-2011, 01:48 PM   #1
Toji
Drives: 2009 Yaris 1,33
Dashboard remove ... ALL of it
Hi everyone!
I am new here. But I am watching a lot of postings from you for a long time.
Now, I have got a problem with my 2009 yaris (vitz).
There are a "big" plastic noise while driveing.
I got it located under/beside the drivers airvent.
And it stops when I lift/pull up the plastic in the knee-area under the steeringwheel!!
I think, it is the mount area of the dash ...
My plan is, to remove the dashboard an underlay it with "felt-sticker" or foam.
So my big question is: do I have to remove the complete dashboard?
If yes, can someone give me some kind of manual for this job? (pictures prefered :) )
Or is it possible to reach this area just by removeing the plastic parts under the steering wheel?
I would be veeery happy, if someone could give me some assistance ..
Toji
Toji is offline   Reply With Quote
Old 02-25-2011, 02:40 PM   #2
swidd
Drives: Yaris HB
There's plenty of post on this.
Old 02-25-2011, 02:51 PM   #3
Toji
I already used the search option of this board. ...
but i couldnt find it.
sorry, may be its my bad english ... i would prefer some helpful pictures! :(
Old 02-25-2011, 03:17 PM   #4
Here is the link to the repair manual. It is the 2007 version, but the dash is the same for your 2009. See page 113 of the "Air Conditioning" section:
http://www.etimago.com/yaris/repairmanual/
Old 02-25-2011, 03:37 PM   #5
Toji
Ah!
I knew this page before...
!!!!!!!!!! Is it so easy to remove the dash? 4 Screws? and just remove the radio before?
is it realy necessary to remove the side-airbag covers first?
Thank you guys!
Old 02-25-2011, 03:42 PM   #6
Originally Posted by Toji View Post
Ah!
Thank you guys!
It is fairly easy. Remove radio trim, radio, speedometer trim. speedometer, cup holder screws, other two screws, and the A-pillar trim.
You do have to remove the A-pillar trim (side airbag covers), because they sit on top of the dash.
Old 02-25-2011, 05:22 PM   #7
swidd
Drives: Yaris HB
http://www.yarisworld.com/forums/showthread.php?t=26144
Old 02-26-2011, 06:30 AM   #8
Toji
hi guys,
i made it. it took about 3hours to remove the whole part, underlay it with some dam stuff and replace it again.
i found a screw in the frame Area, whitch wasnt tied ob as it should.
i think this was a reason, too.
thanks again for support!
i didnt find such a quick and helpful assistance in a nother yaris Forum before.
greetings from germany.
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 12:29 PM
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
