![]() Drives: Slowcart Join Date: Dec 2022
Hi all I'm in the process of building my Yaris currently. Currently I am going all motor. I have done the following: AEM CAI, Weapon R Header, Tooter Intake Runner Extender, 2AZ throttle body, port matched intake manifold, 1ZZ injectors, and FTG Tuning Reflashed ECU with higher redline.
My question is with the increased rpms and (hopefully) more horsepower should I consider upgrading to Brian Crower Titanium Valve Springs and Retainers or will stock springs be ok? I'm planning on doing autocross and track days with it so dependability is super important. |
![]() ![]() Drives: 1983 carina 2NZ-FTE Join Date: Dec 2020
i had valve float about 7000rpm na and 6800 with turbo.
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
Stronger springs are a must for reliability especially at higher rpm
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Pretty much a mandatory upgrade if you plan on spinning it over 7 grand.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
also leave the stock crank pulley on if youre reving that high, lightened pulley will disintegrate
Average KKT User
Drives: 2001 Echo Join Date: May 2020
I would only think about springs if I put a cam in the car. New springs and retainers could never hurt probably increase reliability a lil bit. I've never or don't think I've ever had problems spinning to 8k with stock springs or rods beating the sh!t outta it for 6 months. Have you thought about porting the head if you were to go through all the trouble to change springs? This is my personal opinion ofc. If you want to spend the time and money go for it learn something new in the process make it more reliable what's wrong with that!
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 09:47 AM |
| PCV valve question | window_lee | DIY / Maintenance / Service | 31 | 10-22-2014 05:05 PM |
| Track Suspension | id3379 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 85 | 06-11-2009 06:59 PM |
| spring rates question | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-11-2009 01:33 PM |
| BailOut's Interview: Conservation in 2009 and Beyond | ChinoCharles | Fuel Economy Forum | 43 | 02-24-2009 04:03 PM |
