![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
'08 Hatch Striker Plate Loose (Easy Fix!)
Hey all, a little background I own an '07 3dr Hatch (AT) and just picked up an '08 3dr Hatch (MT).
On the '08 I noticed the hatch striker plate was loose. I took the interior plastic trim off and looked behind the bumper and there are no good access points to this (big enough to fit my hand in), the only access points are two oblong shapes (best described as elongated circles, but not quite). Anyway, I read a few posts regarding this subject and found everything from cutting holes in the trunk to people making special tools for the job to tac welding the striker in place. I did not include how to take off the plastic trim because it was merely removing two (2) plastic fasteners and pulling it off. Well I found an easy fix and I hope this helps someone in a similar situation. Striker Plate: Holes to Access the striker plate nuts: Right Access Hole w/flashlight for visibility: Left side access hole: View through right access hole: Offset box end wrench 14mm (Duralast brand I got from WalMart): Offset box end wrench in right access hole over loose nut: Woohoo! This took me about 5 minutes to complete. Last edited by TommyWasabi; 08-11-2023 at 05:48 PM. |
No pics!
Here are the pics in order. I added them in as attachments in case the net code dookied again.
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
those are supposed to welded nuts, seems to be common that the welds come loose
going to go check mine right now
| Easy fix for Squeaky / Squealing Belt | andrewmcg | DIY / Maintenance / Service | 44 | 06-04-2025 10:22 AM |
| DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) | CTScott | DIY / Maintenance / Service | 15 | 12-30-2015 06:27 PM |
| Any EASY way to add ABS to an 07 3D hatch? | Shinare | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 11-07-2011 04:57 PM |
| 2010 Prius brake problems easy fix. best video ever! | dinamix | Off-topic / Other Cars / Everything else Discussions | 6 | 03-14-2010 11:00 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
