Old 11-07-2011, 04:22 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Any EASY way to add ABS to an 07 3D hatch?
Was wondering if I could trade my "pro-lock" brakes to some ABS or something by adding/swapping some easy parts? Just a dream probably.... heh
Old 11-07-2011, 04:56 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
Oh adding ABS is easy as anything else.
You just remove a TON of components, install the ABS, and put it back together.
Define easy:
just some bolts, wires, tools, brake lines, pump and valve body, and intermediate auto knowledge ? yes
takes all day or several days ? yes
need many new expensive parts and new electrical harnesses and switches ? yes
might not meet the definition of 'easy' depending on your day job
if you were an electrical/mechanical engineer with tools, you could install your own home-grown
sensors to determine 4 wheel speed and integrate that with the transmission speed output and
install your own pump valve, and then spec and build a controller circuit, but by then you could
get a car with ABS built in. again..define easy. this would be 'easy to do' for CTScott but take a
metric f**kton of time of time to execute safely.
find a wrecked Yaris with ABS and strip it, and swap all working parts... would be the cheapest way to go
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-07-2011, 04:57 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Wakey, Wakey!!
carbon fiber hatch problem cwitte DIY / Maintenance / Service 2 11-18-2011 09:37 PM
is it hard to add a 12-volt auxilliary power outlet? RMcG DIY / Maintenance / Service 1 10-10-2011 01:19 AM
Carbon Fiber Seibon Hatch H3LlIoN Items for Sale by private party 14 05-26-2010 10:11 AM
Yaris Hatch Purchase warlock New YARIS Purchase Forum 7 09-02-2007 11:59 PM
Some easy mods for my new Yaris... nickhjort DIY / Maintenance / Service 12 07-04-2007 07:14 PM
