Old 10-01-2023, 02:02 PM   #1
b1gw0mp66
Drives: ‘08 2dr hatch 5spd
unusual fuel tank leak issue
Hello! First time posting here. Have an issue i’ve never seen before and really can’t find much info anywhere about. Am finding that whenever i fill my ‘08 Yaris up to full, gas leaks out from under that red plastic ring where the filler neck attaches to the tank. Quite a lot gushes out, seemingly until the extra gas in the filler neck is emptied out. If I don’t fill it to full I don’t seem to have any leaks whatsoever. That red ring doesn’t seem to have any visible cracks but it does look somewhat warped at the bottom (know the pic isn’t too hi-res to demonstrate). In my research, this does not appear to be a part you can simply remove/replace, but may be mistaken. Seems to just be built into the gas tank. Realize the only solution may be to replace the whole gas tank, but just want to see if there’s any possible way to repair/seal/replace this. Any input is appreciated, thanks!!
Matthew
File Type: jpg 630F5276-02EB-4089-8444-E6860CD1689E.jpg (101.9 KB, 37 views)
b1gw0mp66 is offline   Reply With Quote
Old 10-01-2023, 04:05 PM   #2
Are you first owner? What the hell is a band clamp doing in there? No car rolls off the assembly line using band clamps.
Old 10-01-2023, 04:57 PM   #3
b1gw0mp66
definitely not the first owner. figured something seemed fishy there.
Old 10-02-2023, 07:37 AM   #4
BLH
Drives: 2007 Yaris Sedan
You may want to do a web search.
For a 2008 fuel system or fuel pipe.
I found a few Toyota part vendors online. Some had diagrams of the parts involved and a part number. That would at least give you an idea to how it is assembled and what parts can be found individually.
I looked at some videos on replacing the metal fuel tube from the filler door to the tank. The tank end does have a rubber piece between the tank inlet and the metal filler tube. There are the clamps you are showing in your photo. So it does look like that style clamp is used on a 2008 and many other cars.
BLH is offline   Reply With Quote
Old 10-03-2023, 07:09 AM   #5
BLH
My 2007 Yaris Maintenance Manual.
Shows Fuel Tank Filler Pipe Sub-assembly Lower. To connect it to the top of the tank inlet. Tighten the clamp. The rubber piece has a clamp on it and I imagine is designed to be exposed to gasoline.
Old 10-03-2023, 12:27 PM   #6
I'll be damned. Just took a look at mine and there it is. A band clamp. Surprises me that one is used in such a high corrosion prone area.
First step, remove and replace with a new clamp.
Old 10-03-2023, 04:59 PM   #7
BLH
Videos I saw seem to agree.
Clamp is in a corrosion zone.
Hard to remove due to the corrosion.
The pipe is also known to corrode.
I would also expect a Cheek Engine Light and codes. If the evaporation system tests detected any leaks.
My 2007 runs the test around six hours after turning off the car. Sometimes you can hear the test pump running the test.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 04:20 PM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 11:59 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 02:44 PM
