#127 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I'm sorry I could not find a 14" wheel to try and see if it'd fit, but I'm not sure that it'd be big enough. Unless the mounting holes for the caliper bracket are moved in closer to the center of the hub, probably 10mm??? But you might have to mill down the rear rotors as well to make them fit. |
#128 |
so for the axle comparison..are you 100% sure the xb1 axle is the same as a yaris...ive only eyeballed them but my eyes are telling me they are not the same...the xb1 actualy looks more "delicate" than the yaris unit
currently in the yard neer me is an xb1, xa, xb2, and an XD pending.....no yaris |
#129 | |
#130 | |
ive verifyed the XB1 is NOT the same as the yaris, after looking at the echo it "might" be the same as the echo, checked the XA and it looks to also be the xb1/echo style, but again the spring pockets were different since i have an xb1 on the lift ive compared it to the yaris and can confirm its NOT the same, tho ive not checked the measurements, its visualy different both in how the unit looks but the spring pocket size and depth... thats not to say it couldnt be a bolt in..... next chance i get tho im going to get out to the yard and pull the XB2 axle and atleast stash it in the XB1...and i may see if it bolts up... im currently checking the yard every couple days waiting on the XD's...i want all the engine swap bits!!!! yes i currently own 07 yaris, 08 xb, 06 xb.....so im kinda lookin to see what tweaks i can do to the xb1 as well..... something of note tho..the xb1 looks to have alot of built in rear camber...if someone were looking for camber that would be a way to get it if the arms swap |
#131 | |
Please continue the hard work. |
#132 |
![]() Drives: 2008 dailycross beater on B14s Join Date: Dec 2021
Hey Neinris, glad I found your thread. Are you willing to reproduce a set of those brackets? SE rear beams are rare and pricey. Would rather go this route.
#133 | |
Anyway, I'll ask my friend if he'd be willing to make another set if you're still interested. |
| Runstop Rear Disc Salvageable? | ilikerice | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 05-26-2016 05:38 PM |
| Rear Drum to Disc Brake Conversion | Mark-UPI | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-13-2015 12:26 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Questions About rear disc brake system???? | jyfro_13 | DIY / Maintenance / Service | 4 | 12-22-2009 10:25 PM |
