Old 05-26-2016, 04:07 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Runstop Rear Disc Salvageable?
Need all the info you guys can give me.
Purchased these for really cheap, and I now know why.. These are completely rusted. So bad I am not sure I will be able to reuse most of it, but I will try.
Here is what I am working with. As of right now, I know I am going to need new pads and probably the shims that fit in with the pads. I will take them out and get some measurements if anyone knows another Toyota corresponding part number from another vehicle for these, that would be great..
Also, I feel that the calipers may be seized... possible rebuild kit is in order also..
Going to try and contact Runstop also.. if anyone has any connections with them, that would be awesome too..
-Derrick-
Old 05-26-2016, 07:38 AM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
I came across a site where you can enter the dimension of the brake pads and it will tell you what they fit. I'm not sure how well it works, but it should be able to give a great starting point. Brake pad search.
Possible rear pads: They look like they came off a rear WRX 2.0 with brembos
Edit: Those calipers look alot like lotus or wrx calipers. Brembo 2 pot I would put money on it after doing some more digging.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 05-26-2016, 08:41 AM   #3
If you have access to a sand blaster I'd start there.
Old 05-26-2016, 04:38 PM   #4
ilikerice
ilikerice's Avatar
Smarts.. Thanks for the links and advice. Will look into this more later on.
-Derrick-
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
320mm front rotors and rear disc conversion installed vten Performance Modifications 35 08-19-2009 04:44 AM
