#19 |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Well I found the MAF safe cleaner from CRC and I cleaned the throttle body there was a build up of dust etc at the butterfly, it seems to run a bit smoother with better response. I still have the harmonic vibration at 2000 rpm, I ran out of time to pull the muffler but that will be next, if that fails I will look at the h20 pump and belt tensioners etc, Thanks for the belt tension tip.
#20 |
I take my comment back. I do still ahve this vibration.
Open your door, hold it with one hand, and start revving your engine slowly, and you will feel the whole car shake around 1700-2000rpm. I dont know, more like the car vibrates with the vibration of the car, no way around that? Maybe just cheap engine mounts? |
#21 |
Yah your right mine comes in a bit later around 2000-2600 rpm I bet if more people tried it they may be suprized to find how much harmonic vibration it is.
#22 |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
I havn't felt anything of the sort. *shrug*
#23 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
IIRC there are two total mounts...one tranny side and one motor side?
ergo there will be more vibration than you can bargain for, from say a lexus... get a torque damper/ motor mount stiffy...
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#24 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#25 |
When I'm at the Autocross at 6500 rpm I really don't want it to blow up, thats why I want to get rid of any harmonic vibrations especially ones big enough to feel in the seat of the car, under no load. I still have not had time to remove the aftermarket muffler to see if thats all it is, now go sail away
#26 | |
That's my point... So I'll go sail away - blow it up if you want. |
#27 |
#28 |
LOL, if there is harmonic vibration under no load, there can be more damage done under load without knowing it because it's under laod, for example if there is harmonic vibration is due to a unbalaced crank pulley under load the main bearings could wear uneavenly. Maybe I'm picky, but I really want to isolate where the problem is, if not I'll maybe I can blow it up for you
#29 |
Don't fotget this is an inline 4, which is inherantly unbalanced. A compromise is made as far as the harmonics are concerned to make the engine as smooth as possible at cruise rpm, while transiant harmonics are mitigated as much as possible through component weights (i.e. a heavy crank will have resonant frequencies than a lighter one).
Also, the stock crank pully is heavy for a reason. When I installed the 10% underdrive pulley I noticed an overall increase in vibrations, but everything smooth's out above 2K rpms. |
#30 |
Learn to Relax
#31 | |
Good info !
#32 | |
I did this on my last car made hard launches much smoother and fast shifting better, but a lot more vibration entered the cabin.
#33 |
Half a Bubble Off Plumb
#34 |
![]() ![]() Drives: 2007 Yaris Hatch is sold Join Date: Mar 2017
what a bunch of off-topic nonsense in this thread.
my car has this vibration at 2000rpm too. feels like someone pulls a plug wire (exaggerating) at 2000.... googling brought me here mines a bit shaky at idle too |
#35 |
![]() Drives: 2015 Yaris Join Date: Aug 2017
My Yaris with 1NZ-FE also has the vibration at 2000 RPM (if revved with no load). Since there are other people in here whose cars have the same vibration at the same RPM, then I guess it is just a characteristic of this engine. So, I'm not going to worry about it.
#36 |
![]() Drives: Yaris 1.0 life - 2012 Join Date: Aug 2025
Hello
i have 2012 Yaris 1KR-FE 3 cylinder and i have the same problem around 1400-1500rpm. 1400 + below and 1600 + above are totally pure.. 4 cylinders modal is vibrating in 2000RPM and 3 cylinders (mine) is in 1500.. seems it is the same issue Does anyone help or already solved what can cause it ? |
| FS: 2000 Toyota MR2 Wheels | Snake | Items for Sale by private party | 10 | 12-29-2008 04:01 PM |
| Vibration or shake at highway speed? | evan | DIY / Maintenance / Service | 10 | 11-10-2008 09:23 AM |
| Need help on vibration. | Red Horse | DIY / Maintenance / Service | 4 | 11-01-2008 03:48 PM |
| Post-rotation vibration | kurokoma-kun | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 09-15-2007 05:02 PM |
| 2000 Yaris / Vits Owner's Manual | bobdigi | General Yaris / Vitz Discussion | 1 | 05-30-2007 07:45 AM |
