Old 09-16-2015, 12:27 PM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
2nz-fe engine fuel performance
Hi!
If anyone owns a 2nz-fe engine (1.3 L), please let me know what year is it, if it is automatic or manual and what is your MPG. I would like to know because I just found out that my 2005 Yaris has a higher MPG than my new one. The only difference is that the old one is manual and the new one is automatic but the difference is HUGE, about 50%.
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 10-31-2015, 06:30 AM   #2
Vitz_Q8
Vitz_Q8's Avatar
Drives: 3dr NCP90R
mine is '06 NCP90R Automatic, I get about 6.8L/100km or 34 MPG almost all done in hilly roads with lots of traffic lights, speed limit is 60-70km/h
Vitz_Q8 is offline   Reply With Quote
Old 11-01-2015, 02:16 AM   #3
willieG
Drives: 09 hb 2nzfe m
in my 09 manual hatchback I'm normally getting around 5.2L/100km this year. if i go over half accelerator or over 5krpm it gets up to the over 6l/100km mark. generally 1 tank over 3 weeks mainly 70km/hr with a few km a day at 100
willieG is offline   Reply With Quote
Old 11-03-2015, 04:06 AM   #4
jcboy
Drives: Sedan 07
Used to be 10-11km/l from heavier factory wheel with 185/60 r15 then it went up to 13-14km/l with lighter oem wheels (5-spoke) and same 185-60 tires.
I get around 11 km/l now after new tires 175/65 r15 with the same 5-spoke. Not sure if the decrease is due to penalty for taller tires or bec of the slower readings.
All of which are 100% city driving with medium traffic, lots of stoplights.
HTH
Old 11-03-2015, 06:56 PM   #5
KTS
KTS's Avatar
Drives: Vitz RS
My wife's 2007 auto sedan on 2ron fuel gets about 325km to the tank until the gas indicator comes on. 205-50-15 tyres 32psi/30psi front/rear. A lot of short city trips.
KTS is offline   Reply With Quote
Old 12-10-2025, 10:46 PM   #6
slick1
Curiousity killed the kat
Drives: Yaris 2006, 2015 & 2020
We have a 2006 and a 2015 Yaris 1.3 L auto and both have 2NZ-FE engines.
They both get ~14 km/L most of the time although they can drop as low as 12 km/L if you do some towing or start hooning. They go as high as 16 or 17 km/L on highway runs.
Born under a wondering star
slick1 is offline   Reply With Quote
Old Yesterday, 03:05 PM   #7
Whombom
Drives: t-sport and verso
Had a 2nz 1.3 automatic hatchback, got 5.6l/100km
Currently have a 2nz 1.3 manual verso, also gets 5.6l/100km.
My impression is that a manual box is a bit more efficient, but it is offset by the verso's larger frontal area.
I suspect a 1.3 manual hatchback should be able to get around 5.3 to 5.4l/100
(Also have a 1.0 manual hatchback that gets about 5.2l/100 and a 1nz t sport that gets 5.5)
Whombom is offline   Reply With Quote
Engine 1.0 1kr-fe - too high fuel consumption ubecya DIY / Maintenance / Service 4 02-18-2016 07:08 AM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
