Old 06-28-2014, 05:07 AM   #1
ubecya
Drives: Daihatsu Sirion 1.0
Question Engine 1.0 1kr-fe - too high fuel consumption
Hello guys, this is my 1st post on yarisworld
The car is cheap Toyota : Daihatsu Sirion 2005, 1.0 1kr-fe, manual transmission, mileage 61,000 km.
The problem is it consumes almost 8l/100km of gas (30 mpg), normal consumption should be 5 to 6l/100km.
Symptoms:
* long term fuel trim = -20..-30% on idle which isn't normal
*abnormally black spark plugs (can attach photos, all 3 of them black equally)
* the software reads no diagnostic trouble codes. I use Chinese elm327 Blutetooth + laptop.
* both oxygen sensors seem ok
_____________
1. idle, warm:
http://s30.postimg.org/9n6n2cq3h/02a_idle.jpg
2. car stopped, engine warm:
3. as above:
4. driving, engine warm:
______
Any suggestions? I'm thinking of MAP sensor, crankshaft, camshaft position sensors
Will appreciate any help
BR,
Z.
ubecya is offline   Reply With Quote
Old 06-28-2014, 06:01 AM   #2
ubecya
Hello,
The problem is it consumes almost 8l/100km.
Symptoms:
abnormally black spark plugs (all 3 of them)
The engine starts and works (idle, driving) normally.
_____________
1. idle, warm:
3. as above:
______
Will appreciate any help.
BR,
Z.
Old 06-30-2014, 06:57 PM   #3
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Sounds like it runs too rich.
I would check vacuum leaks, exhaust leaks, clean/replace MAF sensor.
Pozdrowienia.
jack black is offline   Reply With Quote
Old 06-30-2014, 07:33 PM   #4
ex-x-fire
What's the highest temp that the coolant gets to? 65*C ? If it is, then that's too cool.
Old 02-18-2016, 07:08 AM   #5
jackmilas
Drives: Yaris Verso 1.3 2000 automatic
Did you get to the bottom of your problem?
jackmilas is offline   Reply With Quote
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
High compression engine flow-vitz General Yaris / Vitz Discussion 1 11-15-2006 01:03 PM
