![]() ![]() Drives: Liftback Auto Join Date: Dec 2006
AT fluid change interval?
I haven't seen a recommendation on when to have the AT serviced in my manual.
Anyone know the AT fluid change interval? |
It should be in your passport. I think somewhere around 100k.
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Never "needs" changing according to Toyota. Weird stuff. My brother talked to a service guy about his Xb's AT fluid and the guy said the way Toyota makes the ATs - the fluid is good for the lifetime of the car. I still want to put Amsoil AT fluid in at about 50K though.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
So the AT has a regular drain plug?
It does, but there is no drain interval specified by Toyota.
I haven't even found the dipstick for the AT
der Zeck
I am swaping over to Amsoil 75W-90 for my trans as soon as I get a day off of work and have some time to myself, luckily our trans only takes 2 quarts (manual trans that is)
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Regardless what the dealers say all mineral based oils need to be changed sooner or later.
Personally I replace my synthetic autotrans fluid and filter every 75,000-100,000km For manual transmissions I use Amsoil 75W-90 and Never change it however I do drain it, filter it through a coffee filter and re-use it. this removes and harmful debris and water from the oil.
The early bird gets the worm, but the second mouse gets the cheese. |
Roar?
how do you change the manual trans fluid?
What the...?
Drives: '06 Blazing Blue 3 door RS. Join Date: Oct 2006
i smell a DIY for this...
der Zeck
use the drain plug on the bottom of the trans to drain, and use fill hole on the side of the trans to fill it :)
I'm going to call the dealership. I'm sure they have a AT service offer.
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 07:40 AM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
| soo whos gonna change their tranny fluid | twixt | DIY / Maintenance / Service | 0 | 08-04-2006 04:09 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
