Old 06-04-2007, 01:12 PM   #19
rage2
Drives: 07 Black Yaris 5D
The inner plastic lip bulges out quite a bit to clear a nut that holds the bumper on (if I remember correctly). You can cut it, and tape it up to avoid water in the area and you will have an extra 5-10mm of clearance.
rage2
My Yaris Diary - All about my new Yaris!
My Blog - F1 News, Hotties, and Random Crap
My Site - Beyond Car Forums
rage2 is offline   Reply With Quote
Old 06-04-2007, 01:34 PM   #20
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I'm running 17's with DF springs, it rubs a bit in the front too. I havent had it aligned yet so the lil bit of toe out correction will help.
Mine is just the anchor that holds the bumper to the fender, after wearing it a bit it doesnt rub bad at all now. I also rolled the fenders a lil bit with a mag-lite.
Turbo&Auto is offline   Reply With Quote
Old 06-04-2007, 02:31 PM   #21
kimona
kimona's Avatar
Drives: 2014 White VITZ
If you run 16x7's and don't lower the car, then 205/50'16's should be just fine up front with any offset from +38mm to +45mm.
If you lower the car, then you'll have to adjust the offset and/or the tire width/height.
I notice a lot of the Japanese guys run staggerd offsets on their Vitz: They typically run 7's with ET+42mm to +45mm up front and ET+35mm to +38mm in the rear.
Of course, you can't rotate tires with staggered offsets, but that doesn't seem to be a consideration when you're trying to get the wheels/tires to clear properly and to look just right all 'round.
Unfortunately, unlike wheels in Japan, we don't have many available here in the States with multiple offsets, although I have found a few at Tirerack.
Old 06-04-2007, 02:40 PM   #22
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
spacers for the rear
SPONSORED BY
Old 06-04-2007, 05:26 PM   #23
kimona
kimona's Avatar
Yeah, spacers are an easy and inexpensive fix that even things out.
Some guys use spacers and have no problems at all. I've used them before with minor vibration at speed.
Perhaps it's all in the quality of the spacer...
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
FS: 17'' Motegi MR7 Rims and Khumo Tires Sabretooth Items for Sale by private party 11 07-02-2007 02:55 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
