Break'em off some.
Who makes camber bolts?
I need some.
![]() ![]() ![]() Drives: 2007 Toyota Yaris sedan Join Date: Aug 2006
Me too, I need negative.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
You guys check with Invision, Wesellcarparts and Dezod? I think heylookatjames had camber bolts but not sure where from. Doesn't one of the thai guys have camber bolts?
SPONSORED BY
Break'em off some.
I bought some on Ebay for a Scion XB for $15 shipped. We will see if they fit :)
der Zeck
I am pretty sure these are just a smaller diameter grade 8 bolt
Lonesome Cowboy
there is a guy here with these
Toyota OEM 12.4mm Front camber bolts (-2 deg camber) http://www.yarisworld.com/forums/sho...t=camber+bolts
SPONSORED BY
Parallel Parking Pro
![]() My local alignment shop came up with these no-name bolts that gave my car the camber I wanted. Its adjustable from 0-2 degrees negative I believe. |
Break'em off some.
Break'em off some.
der Zeck
then you can get them at Napa
Lonesome Cowboy
you ever get the camber bolts installed?
SPONSORED BY
Break'em off some.
I'm installing them this weekend. I have a camber guage I will use to dial in the camber.
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
Lonesome Cowboy
cool
SPONSORED BY
Break'em off some.
Save $10 and get them on Ebay. Mine were $15 shipped, they are the same ones.
Lonesome Cowboy
maybe kinda dumb question. Can you still use tuner nuts on these?
SPONSORED BY
Break'em off some.
Yea. These are the bolts that attach the bottom of the strut to the spindle. There are 2 per side. You replace the upper bolt on each side with the camber bolt and leave the stock bolt on the bottom.
Lonesome Cowboy
I see it is beginning to make sense to me now. Thanks for explaining that. I'll be interested in hearing how your's performs when you get it adjusted.
SPONSORED BY
| Camber kit | FunkyCole | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 02-05-2009 04:28 PM |
| Camber kit | FunkyCole | Performance Modifications | 0 | 06-12-2007 07:26 PM |
| The ultimate question... WHY? Beware, nothing in this post makes sense. | spkrman | Off-topic / Other Cars / Everything else Discussions | 26 | 05-30-2007 01:01 AM |
| Dont forget the camber bolt. | nurburgring | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-23-2007 04:39 AM |
| Camber Kit? | LoudYar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 04-12-2007 09:58 AM |
