![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
timeing belt?
do we have one and if so how can u check ur timeing and what would i need
"It hurts more when its wet" |
No, we don't have a timing belt; we have a timing chain that is internal and requires no scheduled service.
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
So no need to service it, ever?! Makes me even happier investing in a Yaris~
![]() Drives: 07 Yaris LB Join Date: Jun 2007
Supposedly you have to go in for some kinda service at 100K miles.
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
Chain is much better than a belt as the belt has to be replaced every 60,000 miles whereas a chain only needs an inspection/possible replacement after 100,000.
Kevin |
yes thats what i thought but for some reason it slipped my mind about the timeing chain.... cant that get off timeing like a belt if u do stuff like the crank pulley for instance
Heart Up! Vitz
Thats a relief. I wont be reaching 100k any time soon, unless I decide not to live in a dorm and end up commuting to UCLA everyday from Nor Cal
its a timing chain, which never really goes out of spec, the 100k mile service is normally for the guides and sometimes the tensioners which will usually go bad around 150k, when you will start hearing a metal scraping noise. You normally just get a timing chain kit which includes new everything.
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Timing chains are usually unheard of on an "economy" car like ours. They cost more and also produce a little more noise than a belt. Another reason the Yaris kicks ass! I think the Versa and Fit both have chains as well.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
![]() Drives: '07 Yaris S Sedan Join Date: Jan 2007
Honda is notorious for their use of belts, all Nissans use chains.
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3 Join Date: Oct 2006
i'd take a noisy chain over a timing belt ANY DAY of the week!
| Drivers Side Seat Belt Won't Retract | redyaris | DIY / Maintenance / Service | 8 | 08-07-2014 10:37 AM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 08:37 AM |
| Does the Yaris' engine have a timing chain or belt? | grampi | General Yaris / Vitz Discussion | 8 | 05-12-2007 03:59 AM |
| Best Grease to use on the belt? | hasher22 | DIY / Maintenance / Service | 11 | 04-23-2007 02:20 AM |
| Belt | Kitt | DIY / Maintenance / Service | 3 | 12-06-2006 11:37 PM |
