Old 09-13-2007, 10:34 PM   #199
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
Originally Posted by Chris07LB View Post
I did adjust the lights down just a hair (half a turn counter clockwise), just because i "thought" they might be a little high.
Anyone got a picture of exactly where this headlight adjustment is? Or perhaps someone would care to post a DIY to help keep the roads a little safer. :)
OgDogg is offline   Reply With Quote
Old 09-16-2007, 10:07 PM   #200
OgDogg
Gas Guzzler
OgDogg's Avatar
FYI, on the sedan it's an 8mm nut you have to tighter/loosen in order to adjust the headlights vertically.
Old 09-16-2007, 10:16 PM   #201
uncleyaris
After trying just to change blubs, I be afraid to install HID's, it's so tight for space. Are the instructions that come with most kits easy to follow? IS it a big job?
Old 09-17-2007, 12:51 AM   #202
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Still kickin around the idea of hid's. Who all has the bi beam kit and what is the brand and do they fit ok without any modding of the assembly?
Old 09-17-2007, 10:32 AM   #203
OgDogg
Gas Guzzler
OgDogg's Avatar
I have the hi beam kit and it fits perfectly. You just have to turn the rubber piece behind the bulb inside out to fit the larger bulb casing.
As far as installation goes... It's just as easy as changing the light bulbs only you have the added step of mounting the ballasts.
Old 09-18-2007, 04:42 AM   #204
slvryaris
slvryaris's Avatar
What does everyone think of these kits on EBay??
http://cgi.ebay.com/ebaymotors/HID-B...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/XENON...spagenameZWDVW
I know low price soooo........Has anyone had problems with the Bi beam fitting. I Imagine they would all be of correct size and not oversized.
Old 09-19-2007, 09:07 PM   #205
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
Hey, see my post at http://www.yarisworld.com/forums/showthread.php?t=8922.
I tested a bi-xenon kit from Xenonlink.com and it did not fit in my LB's headlight setup. The springs that hold the bulb in would not work with the HID bulb. I'm sending the kit back for a refund.
I have ordered another kit from xenithxenons.com, who have tested their bi-xenon kit on Scion xBs, which also use H4 and have a similar spring retaining system so hopefully this kit should be compatible with our cars.
I'll let you guys know what the results are.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 09-26-2007, 12:47 AM   #206
slvryaris
slvryaris's Avatar
Did anyone ever figure out how to adjust the headlight??? Or do you just tuen that 8mm nut?
Old 09-26-2007, 06:07 AM   #207
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Pop your hood.. look for a black round barrel on the inside (engine side) of the light housings, with a white + in the center.. thats your adjuster.
Old 09-26-2007, 07:28 AM   #208
slvryaris
slvryaris's Avatar
Right on. I posted the comment when i was at work and in a hurry. I just checked the manual online and seen it, but for some reason I couldnt find it before. I guess I will try to lower the headlights before I give up on the HID's until someone starts selling retrofitted headlight assemblys so I dont have to mess with it. Also Chris I was curious how you have the stock assemblys and no one has flashed you. Is it in the bulb for some people like with the glare shields or de people re aim??? I just have no idea how people have HID's without retrofitting or lowering the assemblys.
Old 09-26-2007, 07:31 AM   #209
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
This here:
Old 09-26-2007, 08:34 AM   #210
slvryaris
slvryaris's Avatar
Sedan is different. Just went outside andfound it. It looks like a light grey wheel with a 8mm nut in the middle. I just turned it clockwise and lowered my lights. Looks a 100 times better.
Old 02-28-2009, 01:13 PM   #211
Soccer_Yaris
Drives: Toyota Yaris RS
I am now returning the 8000K hid lights back to the store. After installing the lights I found out that I cannot have these lights working on my car with the DRL module. In Canada its the law to have DRL ( Daytime running lights). It would be a $360 ticket without it. So I contacted the supplier and he told me to return it. Thats $300 bucks back in my wallet!
Soccer_Yaris is offline   Reply With Quote
Old 05-07-2009, 07:26 PM   #212
Uaaurelia
Drives: Yaris RS Hatchback
anyone know what to do with the yellow wires for the halogen on the top, where to connect them too?
Uaaurelia is offline   Reply With Quote
Old 05-07-2009, 07:31 PM   #213
Chris07LB
Chris07LB's Avatar
When you unplugged your halogen bulb, the connector should have 3 wires in it.. is this what you are talking about?
Old 05-08-2009, 07:30 AM   #214
Uaaurelia
i bought the High/low H4 kit, came with a halogen bulb for the high beam. it came with two yellow wires for the halogen light bulbs. i dont know where to wire them too
Old 05-08-2009, 09:09 AM   #215
ham
ham's Avatar
Drives: 2007 Yaris Hatch 5-Speed
Originally Posted by 07yaris_fe View Post
anyone install HID kit to 2007 Yaris???
I'm having problem with the HID kit that i have.
I got a H4 HID kit it work but my DRL have problem
anyone can tell me how to disable the DRL?
Once I release handbrake, the light keep flashing........
so how i'm driving with my HID on all the time =(
please help!!!!!!!!!!!!!!!!!!! THANKS
That sounds all kinds of messed up.
Send me a link for your kit or a copy of the wiring diagram and I'll solve your problem. I also have a 2007.
ham is offline   Reply With Quote
Old 05-11-2009, 06:24 AM   #216
Uaaurelia
yea me too. i got the High/low HID kit. when I connect the yellow wires from the halogen light (high beam). i get the flashing lights from both high and low beams.
i dont know if i connected the yellow wires right. Anyone knows where to plug/wire the yellow wires to or a pic of the wiring??
