Old 09-26-2007, 08:46 PM   #1
stubagg
Drives: 07 Yaris HB
Unhappy Idle
My 07 HB idles up and down. Anything i can do to fix this?
stubagg is offline   Reply With Quote
Old 09-26-2007, 08:51 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
NST pulley set
Old 09-26-2007, 08:56 PM   #3
stubagg
Drives: 07 Yaris HB
do they all idle like this?
Old 09-26-2007, 09:00 PM   #4
Black Yaris
der Zeck
yes
Old 09-26-2007, 09:04 PM   #5
BailOut
Steals terrorist's lunch
BailOut's Avatar
No, they don't all do that, and to suggest a 3rd party replacement part for a vehicle that's still under warranty is irresponsible at best and shady at worst.
Rather than exert a lot of effort to diagnose a problem with 20 or so potential causes I suggest you just take it to the dealership and let them do all the work.
- Brian
Share the Road
Old 09-26-2007, 09:06 PM   #6
Black Yaris
der Zeck
ok not all of them do that.... just 99% of them.... and BailOut is a.... yeah, not even worth it anymore
Old 09-26-2007, 09:11 PM   #7
RShatchback
Drives: 07 yaris liftback
Whats a warranty?
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 09-26-2007, 09:13 PM   #8
ahhh, the unclear word of a dealership. lol...
Old 09-26-2007, 09:15 PM   #9
by idling up and down, do you mean when you come to a stop, it'll drop below "idle" speed, then go back to normal "idle" speed? do you have the a/c on? i think that'll cause it to go above normal (briefly), then go back to normal.
Old 09-26-2007, 09:18 PM   #10
Nibs
Nibs's Avatar
Drives: 07 Yaris HB black
I took mine to the dealership a week after I had it for this same reason. It only does it if the A/C is on or you have one of the two defrost options on. Its the rely or something kicking in then turning off. What the dealership told me anyways.... if you turn to any of the other vent options you won't have that happen
Nibs is offline   Reply With Quote
Old 09-26-2007, 09:20 PM   #11
yeah, i noticed that too when i turn on the rear defroster. idle drops briefly, then goes back to normal.
Old 09-27-2007, 12:39 AM   #12
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
It's probably A/C related. In absolutley no way could an NST pully set cure this problem. Bad advide.
Old 09-27-2007, 07:15 PM   #13
IllusionX
Drives: 07 Yaris Sedan Aero
defrost turns on the AC compressor. so yeah... you will see your MPG dropping significantly if you always drive on defrost :)
Old 09-28-2007, 02:00 PM   #14
tsportman
tsportman's Avatar
Drives: Yaris 1.8 TS
It's pretty normal, when the a/c compressor kicks in, it takes about 3-5 hp !
The engine management needs to correct that and even it only takes a second, you get the impression that the idle is going like a jojo !
It does that very irregularly, depending on chosen inside and outside temperature.
Nothing to worry about, lots of cars have this phenomonon.
tsportman is offline   Reply With Quote
Old 09-28-2007, 02:09 PM   #15
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
Mine idles just fine.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 09-28-2007, 04:16 PM   #16
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
you may have blown a head gasket
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-28-2007, 04:17 PM   #17
KSIbucky
KSIbucky's Avatar
some times you idle is up and down because your car is trying to adjust to driving condition
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-28-2007, 05:08 PM   #18
BailOut
BailOut's Avatar
- Brian
Share the Road
Idle Fluctuation due to aftermarket intake? Galavoxx Performance Modifications 38 12-31-2011 09:31 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 09:23 AM
idle rpms up and down... Nibs General Yaris / Vitz Discussion 10 05-12-2007 04:39 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 04:40 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 09:41 PM
