Old 12-17-2006, 06:05 PM   #1
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Idle Fluctuation due to aftermarket intake?
Installed the Weapon Research intake just last month and now I have this intermittent idle fluctuation. It doesn't happen all the time but the symptoms are always the same. After the car is warm, rpms will rise to 900-1000 rpms and then drop to around 700-650 rpms. This will continue to happen as long as the car sits at idle. I usually notice it when I pull up to a stop light. As I said, this doesn't happen all the time. Was wondering if anybody else has this issue with any of the other intakes or if this is a common problem? From my experience with motorcycle carburation, this symptom usually means that the idle jet is too big. Since this car is injected, I have no idea why it might be doing this. Seems like it happens more when it's humid outside but that could be my imagination. I also have a custom cat-back magnaflow exhaust. This could also be part of the issue.
Galavoxx is offline   Reply With Quote
Old 12-17-2006, 07:00 PM   #2
jcove
jcove's Avatar
Drives: 2011 Rogue
I'm not sure about everyone else, but I see this from time to time. I have a Vibrant Exhaust right now, but it was doing it a little before. doesn't seem to be a problem.
jcove is offline   Reply With Quote
Old 12-17-2006, 07:05 PM   #3
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
I don't have a tachometer, so I don't know what the RPMs look like... I also have no Engine Mods... Just a Short Shifter Kit... But sometimes when my Yaris is fully warmed and sitting Idle at a red light... The engine starts shaking the car slightly... And it definitely has a rhythm to it! I was starting to think this was a normal thing in small cars, but this post has just made me nervous!
Nutzoids is offline   Reply With Quote
Old 12-17-2006, 09:13 PM   #4
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
my yaris did it when it was stock, still does it after exhaust on it. exhaust didnt change it. something about the engines idle control...i noticed it does it at any time when at a stop when the transmission is in neutral and it is iddling...it normally sits at 800rpm...then it drops to 500rpm and the engine shudders and then it spikes to 1000rpm.
im sure its either normal or a recall that toyota will send out at a later date,lol.
Old 12-17-2006, 09:21 PM   #5
that has happened to me a couple of times, and my Yaris is bone stock.
Old 12-17-2006, 10:21 PM   #6
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Ok. SO it's not something with the Weapon intake. That's good. I thought I might have an intake leak or something. It does make me wonder why this is happening though considering it happens to cars that are stock and that have mufflers and intakes. Maybe poor engine mapping or an overly sensative ECU. Electric power steering maybe?
I'd like to get a little further into this. Anybody else have this problem or who might have a possible explanation? Chris? Chino? eTima?
Old 12-17-2006, 11:00 PM   #7
I don't really remember how it was before changing the intake and exhaust, but I think it is normal, especially as we have an electronic throttle, the ECU always does some tricks with it.
Plus, when idling, the ECU also alternates between a rich and a lean fuel mixture, this is to keep the catalyser working at peak efficiency, so it may also have an effect on the idling speed.
Old 12-17-2006, 11:19 PM   #8
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
interesting. Have you had this problem?
Old 12-18-2006, 12:22 AM   #9
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
It happens bone stock to all of us. Notquite sure why. It is in the stock programming.
DTM_Yaris is offline   Reply With Quote
Old 12-18-2006, 02:02 AM   #10
Well I usually have the air conditioning running, so that itself will cause the idle to fluctuate, but when it's off, yes, it will go up and down over time. I really don't think it's anything to worry about.
Next time I drive I'll keep the AC off and double check to see if there is a relation between the AF ratio meter and the RPMs.
Old 12-18-2006, 11:37 AM   #11
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
After hearing that this is a common problem, I don't think it's anything to worry about in terms of potential mechanical issues. What bothers me is that this is a new car and as such there should be no idle fluctuation once the car is warm. Thanks for the input.
Old 12-18-2006, 11:58 AM   #12
Sure, but as the saying goes, it's a feature, not a bug
Old 12-18-2006, 12:25 PM   #13
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
It sure is! It's to let you know the car is till on :P. I remember the first time I gave a some friends a ride they were quite sure the car was off! :P
My car does the same thing too. Next time I go to the dealership for the oil change (bought the package) I'll ask the tech about it (if I remember).
TrancosRt is offline   Reply With Quote
Old 12-18-2006, 03:21 PM   #14
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Mine does that as well, idles around 800-1000 then drops and shudders slightly. I cant imagine that is a built in feature for anything... I had the same problem with my previous car.
Funny thing is the Yaris developed this idle fluctuation about 10000km not right off the lot. Does the yaris use the throttle body for idle air control or is it a seperate valve as on other makes/models?
mikeukrainetz is offline   Reply With Quote
Old 12-18-2006, 03:41 PM   #15
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I have no idea...
Old 12-19-2006, 12:18 AM   #16
As far as I remember from the technical manuals the idle is controlled by the electronic throttle.
Old 12-20-2006, 06:35 PM   #17
H2XcapePod
Drives: 07 Yaris LB
yup...I noticed the same looping a while back and thought it was kinda sweet! Usually you only get that on tuned cars...the aspirations of a bone stock Yaris...
H2XcapePod is offline   Reply With Quote
Old 12-21-2006, 09:31 PM   #18
foxtrot685
Drives: Scion xA
i have a scion xA and it used to do teh same thing when i first got it. im thinking its common with the 1NZ-FE. give it some time and miles and it should go away... mine did
foxtrot685 is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
