Old 11-23-2008, 08:43 PM   #19
IsLNdbOi
IsLNdbOi's Avatar
I used my Kappas briefly with the stock HU and they sounded fine. When I upgraded my HU, I also installed an Alpine 4.100 PDX amp..
Dunno if the Kappas just don't sound good or what, but to me the stock speakers on my new Yaris sound better than the Kappas ever did. The Kappas were kind of harsh sounding. Also, I always had this hiss coming from the passenger side tweeter. Did everything I could to try and stop the hissing. I replaced the tweeter w/ a replacement from the manufacturer, etc. and the hiss never went away. I even went as far as running a 4ga. ground wire direct from the battery to the cabin and then grounded all of the electronics to that.
Old 11-24-2008, 11:08 AM   #20
IllusionX
Drives: 07 Yaris Sedan Aero
the problem is not the speakers... you just need an amp stable at 2ohm.
but as far as for the hissing sound.. it could be a combination of many things.. so, i can't help.
Old 11-24-2008, 02:24 PM   #21
IsLNdbOi
IsLNdbOi's Avatar
The PDX 4.100 is stable at 2ohms. As far as the hissing, it doesn't matter anymore since that setup stayed wit the 3-door '07 LB which I've already traded in for my 5-door '09 LB.
Old 11-24-2008, 03:41 PM   #22
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
I'm running:
Focal K2P 165KPS Front
Focal Polyglass 130CVX Rear
** Beware of counterfeit Focal products. Only purchase from authorized dealers.
Speaker Sizing - Hatchback
You can mount 6.5" in the front and 5.25". I have also seen 6.5" in both the front and rear with modified spacers.
If you are using high end components, you will need a spacer to raise the speaker so the window doesn't hit the speaker's magnet when you open your windows. I used 3/4" MDF for spacers - see the template in my sig or the sticky at the top.
Another potential problem.. the inside of the door panel has some contours and extruding plastic that might make contact or touch the speaker when you put the door panel back on. A dremel and some sanding will remove some of these extruding plastic so the door panel can fit on properly.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 11-29-2008, 01:38 AM   #23
rg570lvr
Drives: '08 Yaris MM 3d Lb, auto
I installed the front pair of Polk db651 speakers and they fit with the supplied thin rings with plenty of room to spare and sound awesome. I'll tackle the rear speakers later.
Hackers suck!
rg570lvr is offline   Reply With Quote
Old 12-05-2008, 11:18 PM   #24
rg570lvr
I just put the rear pair in and it was really easy with the same pair of rings and now my car sounds so much better even with the stock deck. I ordered a Sony CDX-GT630UI to replace it, just hope I made a good choice.
Hackers suck!
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
Using stock speaker as adapter pricerc In Car Entertainment + Electronics (audio / video / alarm) 4 03-28-2007 07:45 PM
For those wanting speaker brackets.... jdubau55 In Car Entertainment + Electronics (audio / video / alarm) 7 03-03-2007 05:50 PM
speaker holder speaker box KSIbucky In Car Entertainment + Electronics (audio / video / alarm) 10 11-18-2006 01:34 AM
Speaker Spacers - Pi**in me off!!! hasher22 Cosmetic Modifications (Exterior/Interior) 4 08-12-2006 11:28 PM
