Old 11-20-2008, 01:39 AM   #1
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Speaker help
So I'm aware that the LB speaker sizes are 6.5 front, 5.25 rear..
What speakers are you guys using?? (:
Sponsored by: Micro Image
http://microimageonline.com
Old 11-20-2008, 02:14 AM   #2
I haven't replaced mine yet, but I've heard nothing but good stuff from the Infinity Kappa series.
Old 11-20-2008, 09:35 AM   #3
precision power 356CS front
8" dual voice coil mid-bass rear.
Old 11-20-2008, 11:08 AM   #4
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
(4) Memphis Car Audio PR63S 6.5" 3-way speakers powered by a Memphis Car Audio Class A MC4.75 amp with an Infinity Basslink II self powered sub.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 11-21-2008, 01:42 AM   #5
rg570lvr
Drives: '08 Yaris MM 3d Lb, auto
didn't replace mine yet, but I just ordered 2 pairs of Polk db651 6.5" for front and back from Crutchfield. Was told they wouldn't fit, we'll see.
Hackers suck!
rg570lvr is offline   Reply With Quote
Old 11-21-2008, 02:24 AM   #6
TEHxFALLEN V1.2
hmm.. keep it coming!
I'm looking for someone who has aftermarket speakers the size of OEMs (6.5 front, 5.25 rear)
Old 11-21-2008, 11:05 AM   #7
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Those are what I have, they fit and you just use the brackets that come with them. Very nice speakers. I have them running off an Alpine amp.
Why would you want 5's in the Rear? You could fit a 8 sub in there if you tried.
bdc87 is offline   Reply With Quote
Old 11-21-2008, 04:10 PM   #8
TEHxFALLEN V1.2
Oh, they come with their own brackets?? Sweet!
I just want speakers that plug and play, can't be bothered fabricating things and stuff.
Old 11-21-2008, 07:03 PM   #9
rg570lvr
Thanks bro, I feel a lot better now. Was prepared to cut out whatever type of brackets needed. I had the 5" by 7" models in my truck I used to have and they sounded so good. What size amp are you using?
Hackers suck!
Old 11-21-2008, 07:36 PM   #10
bdc87
bdc87's Avatar
The bracket is plastic but it works jsut fine. Using Alpine MRP-F300 4x50W RMS
Old 11-21-2008, 11:51 PM   #11
rg570lvr
Thanks again.
Hackers suck!
Old 11-22-2008, 02:29 AM   #12
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
crystal mobilesound sscs6 in the front(6.5") and crystal ssx510 (5.25") rear, got them at a good price and just wanted to drop them in for fill purposes, and crystal comp x212 sub
staypuft is offline   Reply With Quote
Old 11-22-2008, 09:17 PM   #13
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
infinity 6.5" component speakers in my doors. i know i have a sedan, but, same size and application roughly. infinity has always been a good bang for the buck for upper scale speakers. however, they dont have the best midbass(not tone or quality, just quantity) in my experience unless new stuff of theirs has changed that.
Old 11-22-2008, 09:56 PM   #14
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Will be putting in the Elemental Designs v6000s in the front when I exchange them out for the new speakers they have coming out.......for the backs jsut gonna add a set of Infinity Kappas for fill and in the sub stage using an IMage Dynamics ID10 D2
Components powered by NINe.4 and Sub powered by NINe.2
Old 11-23-2008, 05:06 PM   #15
sportin83
Drives: 2008 blazing blue yaris LB
i am running alpine type-r 6 1/2's front and back.
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 11-23-2008, 05:14 PM   #16
IsLNdbOi
IsLNdbOi's Avatar
I had Kappa 60.7cs set up front and 62.7i in the rears on my '07LB. You can put 6.5" speakers in the rear.
Old 11-23-2008, 06:16 PM   #17
TEHxFALLEN V1.2
How are those Kappas?
Old 11-23-2008, 08:20 PM   #18
the infinity kappas .7 series are 2ohm speakers. you NEED a 2ohm stable HU or amp to use them. (the OEM deck will do fine in 2ohm) Infinity says 2.x ohm become closer to 3.5ohm when heated up, hence no problem in any configuration.
i had tested the 60.7CS in my echo before... i tried them with a nakamichi HU, JVC DVD player and finally my alpine 9855. none of them handled the kappas properly except the fujitsuten oem HU.
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
Using stock speaker as adapter pricerc In Car Entertainment + Electronics (audio / video / alarm) 4 03-28-2007 07:45 PM
For those wanting speaker brackets.... jdubau55 In Car Entertainment + Electronics (audio / video / alarm) 7 03-03-2007 05:50 PM
speaker holder speaker box KSIbucky In Car Entertainment + Electronics (audio / video / alarm) 10 11-18-2006 01:34 AM
Speaker Spacers - Pi**in me off!!! hasher22 Cosmetic Modifications (Exterior/Interior) 4 08-12-2006 11:28 PM
