Old 12-08-2008, 08:45 AM   #37
voodoo22
Drives: Yaris Sedan (auto)
There is no way to be certain of MPG accuracy on a per tank basis, no matter what your methods are. The only way to be somewhat sure of your accuracy is time and quantity. The more tanks you put in, the more statistically accurate your data becomes.
If you always fill up to the first click, then record that data, over time your number will become more accurate.
voodoo22 is offline   Reply With Quote
Old 12-08-2008, 05:39 PM   #38
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
Nice to know about the hose
Originally Posted by b_hickman11 View Post
There is no such thing of gas going back into the pump. Once the noozle flapper is closed, no gas will go back into it. I used to work at a gas station and there are no pumps that suck gas back into them. This is why when you have completely paid for your gas and the pump is turned off, you should re-insert the noozle and give it a squeeze to release the fuel(that you paid for) that was left over in the hose. But it will not go back into the pump.
Does that mean when I get to the pump it is very likely that there is (free) fuel in the hose that I can get in my Yaris........before I pay to get my gasoline? I should empty the hose......then pay for my normal fillup?
roadrunner is offline   Reply With Quote
Old 12-08-2008, 06:37 PM   #39
b_hickman11
Drives: 08 Sedan
Yes....also this is why people complain about some pumps charging customers before they depress the noozle to release gas into their tanks. If the previous customer drained the hose as I mentioned before, some pumps will re-fill the hose the next time someone pays for gas, charging the next customer.
Old 12-09-2008, 11:15 PM   #40
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
It really varies driver to driver as has been said many times already.
Its cold here (7F with wind and snow) and I dont drive slow, usually speeding up quickly and downshifting hard before lights. and I have been getting 40mpg religiously.
Old 12-15-2008, 04:04 AM   #41
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Winter always gives me crappy MPG figures no matter what vehicle i drive,
During the summer i can get 700kms per tank on my 08 sedan or my 01 Echo,Past couple of weeks its been fill up time at around 400kms,i doubt if i could reach 500kms with a full tank these days.
Old 12-15-2008, 03:33 PM   #42
otterhere
Drives: 2008 Yaris 3-door Meteorite
Originally Posted by IwantmyMPG View Post
Hi guys, i have a 2007 Yaris and i was only getting about 22 mpg. That cant be right! I took it to a dealership Maita Toyota http://www.maitatoyota.com/ and they did a tune up which jumped to about 24mpg. They said its my driving style, could that really effect it that much?
Sure you're not using third gear instead of "D"? That was my problem for quite some time. Little children, do not do what I have done!!!
otterhere is offline   Reply With Quote
Old 12-16-2008, 02:33 PM   #43
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
Lifetime average is the best bet! Check the sig..
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 05:23 PM
Toyota Yaris achieves over 84 mpg in MPG Marathon tk-421 Off-topic / Other Cars / Everything else Discussions 5 11-17-2008 08:41 PM
Toyota Yaris MPG Review at www.mpgomatic.com aca72 Fuel Economy Forum 23 10-31-2008 04:59 PM
Am I calculating MPG correctly? YarisBlazer General Yaris / Vitz Discussion 24 08-18-2007 12:57 PM
