Old 08-09-2007, 09:47 PM   #1
YarisBlazer
YarisBlazer's Avatar
Am I calculating MPG correctly?
Ok, this is the second time I've tried to figure out my MPG; I want to make sure I am doing this right; this is how I calculate it:
Odometer reading now minus odomter reading at last fill-up divided by amount of gas I put in tank at this fill-up
Of course I always fill it all the way to full
I just filled up so today's equation is:
2623 (Odometer reading now at fill-up)
- 2262 (Reading at last fill-up)
____
361 divided by 11.551 gallons = 31.252 MPG
Is this right? I am doing mostly city driving so I would like to get this up to at last 36 MPG if I can; I'm in Florida so must run the A/C while driving.
Thanks for any input; my last reading was 32 MPG.
YarisBlazer is offline   Reply With Quote
Old 08-09-2007, 10:44 PM   #2
xed
xed's Avatar
Drives: '08 Polar White 3dr
Yep you got it.
xed is offline   Reply With Quote
Old 08-09-2007, 10:52 PM   #3
petesimac
Drives: Yaris LB
Only thing is, the tank only has a capacity of 11.5 gallons; how did you cram in more? Are you running the car all the way until it is on fumes? If so, that could be part of the problem. I've heard of Yari that run out of gas (or perhaps come close) needing to be reset afterwards. I fill up as soon as the second to last bar disappears, leaving the one, flashing bar. At this point, my tank can only take just under 10 gallons to fill it up again.
Oh, and instead of having to recalculate your miles, use your trip odometer instead. Everytime you fill up, press and hold the little black button near the trip odometer meeting until it goes back to 0; that'll leave you with one less equation to complete.
petesimac is offline   Reply With Quote
Old 08-09-2007, 11:10 PM   #4
swng
swng's Avatar
Drives: 06 3-dr auto RS
Please refer to Post #1350 of the Fuel Economy Thread here for some useful mpg calculators:http://www.yarisworld.com/forums/sho...p?t=38&page=90
There is another one in Post #1422 of the same thread.
swng is offline   Reply With Quote
Old 08-09-2007, 11:11 PM   #5
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
i'm confused as how you got that many gallons of gas into that gas tank as well. and like petesimac says, use your odometer. that's what it's there for. I use trip A to calculate MPG and trip B to calculate next oil change
Don't Milk the Cat!
-Said by me during a game of Cranium.
sherryberry is offline   Reply With Quote
Old 08-09-2007, 11:16 PM   #6
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
____
great..my brain stuck at the dividing part..
oh whatever!!
i know i did one and a half gallon from El Monte to Victorville.
and..when coming back, a little less than that..., damn i love my Yaris!!
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-09-2007, 11:20 PM   #7
swng
swng's Avatar
Re Posts #1,3, and 5 above:
My practical experience is if you ignore the click of the nozzle and try hard to overfill, it is possible to "squeeze" more than the max volume specified in the user manual into the tank. It may not be advisable to do so though. Please see:http://www.epa.gov/donttopoff/
Old 08-09-2007, 11:20 PM   #8
YarisBlazer
My last bar was flashing; my gas recept said I put in 11.551 gallons; I dont know how it happened either; maybe I have a big tank ?
Old 08-09-2007, 11:34 PM   #9
swng
swng's Avatar
Some useful experience shared here:
http://www.yarisworld.com/forums/sho...+tank+capacity
Not every post there is relevant to the present topic though.
Old 08-10-2007, 07:16 AM   #10
Pars
Drives: 07 Yaris Liftback
Try another gas station, perhaps their pumps are better calibrated.
Pars is offline   Reply With Quote
Old 08-10-2007, 10:39 AM   #11
sherryberry
wow i didn't know that some gas stations does that to rip people off. I don't think i've had an issue where the amount of gas i put in is more than the amount of the tank.
Don't Milk the Cat!
Old 08-10-2007, 11:25 AM   #12
petesimac
Drives: Yaris LB
How long had it been flashing? If it had just started to flash, there's no way you put over 11.5 gallons in. I second the suggestion to try a different gas station, and then try to use that station from then on. Plus, find a way to fill up to the exact level each time. For instance, when I fill up, as soon as I get to the 9 gallon mark I slow the pump down to ensure that it fills up to the click without clicking prematurely due to splash or foam. I would also argue against filling past the click, for a variety of reasons, not the least of which is overspill which could damage your paint as well as the environment.
Old 08-10-2007, 11:33 AM   #13
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
0.05 G takes up 11.5 in^3.
The chances a gas station will take a chance with a less than 0.5% overcharge - because the pumps are checked often by state agencies for calibration - are much much smaller than Toyota not making the tank EXACTLY 11.5g... Especially when gas stations make next to no profit on the fuel they sell...
WRBlue is offline   Reply With Quote
Old 08-10-2007, 11:33 AM   #14
nsmitchell
nsmitchell's Avatar
Thank you! DON'T TOP OFF!
:SherryBerry, you have an indicator light (MainT Req) that tells you when to change the oil. Every 5000 miles. You just reset it. http://www.yarisworld.com/forums/sho...09&postcount=5
Get YarAss in gear!
RIP - Casey Tatum
Old 08-10-2007, 12:38 PM   #15
sherryberry
oh i know the indicator light is there. I just like to look at the miles as well and it gives me an idea that it's coming up soon.
Don't Milk the Cat!
Old 08-10-2007, 01:06 PM   #16
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
About 3-5 years ago a few gas stations were found to have black market chips in their pumps (I believe Cali but not sure??) that would show more gas than pumped, only between the full gallon divisions (say 5.4 gallons actual instead of 5.5 shown on the pump...electronics are wonderful!!!!!). They were getting away with it because the inspectors only checked at the full gallon marks.....has our government changed their inspection techniques...and do the stations know when they'll be inspected? Easy way to make up to an extra 30 cents on a fillup......I'd change gas stations.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 08-10-2007, 11:10 PM   #17
Pars
Back in the 80th, I used to notice some very suspicious result from my fill-up. I actually went to complain to the manager on one occasion cause the fill-up was more then my tanks capacity. Back then, most of the cars on the road were these gas guzzling V8 and being a few litre off wasn't a big deal. But I was driving a new 1.6L Toyota and a few Litres would take me to school and back. Since then, I've been very selective about where I go to fill-up.
Old 08-11-2007, 10:10 PM   #18
EggMan
EggMan's Avatar
Drives: 2007 Yaris liftback
The owners manual (page 296) states 11.1 Gal capacity for my Liftback.
EggMan is offline   Reply With Quote
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Wow, I Got 48.57 mpg Kaotic Lazagna General Yaris / Vitz Discussion 52 05-10-2007 10:09 PM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 10:07 PM
Rims, Tires, and MPG Pavel Olavich Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-23-2007 07:28 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 09:56 AM
