Old 12-09-2008, 09:43 PM   #19
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I think the spring spacers are a great idea, but I've already swapped the stockers back on. I think the tire/wheel combo is really the issue, and its only a hair too much, but I'm a stickler for function over form. I'm gonna put my money into a TRD sway bar and go for adjustable shocks somewhere down the road. Interestingly, I had NO problems with the spacing on the rears, in fact they were ideal, even with a bass amp back there. Maybe the fronts were just a bit too soft. More research required...
SilkySmooth - the 215's are not big tires, as you suggest. Maybe an inch wider than stock. And 15's are stock rims, although the rims size is TOTALLY irrelevant to the discussion, as the tire profile determines the overall diameter. Mine are actually about 1/8" SHORTER than stock.
Old 12-09-2008, 09:43 PM   #20
ozmdd
ozmdd's Avatar
If anyone wants some slightly-used TRD lowering springs, I'll take $100!
Old 12-10-2008, 07:39 AM   #21
MUSKOKA800
MUSKOKA800's Avatar
I'm sure the bumpstops are not his issue. He sayes it rubs at speeds from 20 mph and up. The bumpstops only come into play when the suspension is fully compressed as in BIG BUMP at HIGH SPEED.
The issue is surely too much rubber too close to the fender. Narrower tires, more wheel offset, and more negative camber (which would decrease tire life) are a few solutions.
Sound like the tire-wheel combo is just not correct for the Yaris.
Old 12-11-2008, 09:18 PM   #22
sidewinder
"Gettin Jiggy wit it"
sidewinder's Avatar
Drives: 09 Yaris " S " Hatchback
trd springs
Your tires are too wide, I had 215 width on mine and had the same problem, change to 205 width and this should go away.
sidewinder is offline   Reply With Quote
Old 12-12-2008, 10:17 AM   #23
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
FYI: i asked our installer here and he says he has NEVER cut the bumpstops on any trd spring install.....
Old 12-12-2008, 10:49 AM   #24
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
its the 215 thats doin it. suppoe to be stick with 205
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Are my trd springs installed upside down? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-17-2008 11:12 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
NF210 versus TRD springs nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 04-01-2007 04:30 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
