Old 11-17-2008, 12:42 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
Are my trd springs installed upside down?
So if you have read my other posts i been having a lot of noise with my springs. Looking at other pictures of other members i think mine may be upside down. Do the tightly coiled springs supose to be facing up or facing down?
Old 11-17-2008, 01:15 AM   #2
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
any pics?
Old 11-17-2008, 03:13 AM   #3
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
lol i did the same thing you talkng about the back ones right? The ones that are close together are suppose to be up to the chassi(sp) but it shouldnt make a diff as long as its the same diameter as top and bottom. Mine is upside down too ;) no problems
Old 11-17-2008, 09:10 AM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
There actually is a difference in the ride with the springs upside down.
There was a pretty long thread about this before the hack.
Old 11-17-2008, 09:52 AM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
So that means.... Fix em you guys =D
Its a Chao!!!
Old 11-17-2008, 11:04 AM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
The flat side of the spring goes to the top, but there is no difference in ride if the rears are flipped. Springs are springs.
The ride height could be slightly changed if they are flipped or clocked differently, but they do not magicly change spring rate if upside down.
Old 11-17-2008, 11:05 AM   #7
TheRealEnth
Beast
Yeah but just so it doesnt bother you inside thinking about it because you will be paranoid about it... fix it <3 pics pics pics
Its a Chao!!!
Old 11-17-2008, 11:36 AM   #8
largeorangefont
Break'em off some.
Mine are in right, but no it wouldn't bother me.
The fronts would be a big problem if flipped however.
Old 11-17-2008, 12:47 PM   #9
kou
Drives: 08 lb
the one thing that might make a difference is if the end of the coil is not facing the same way as the other, i.e both facing < <.
Old 11-17-2008, 02:15 PM   #10
largeorangefont
Break'em off some.
Yes, if they are clocked wrong, it could affect ride height, depending on how much the car is lowered, and how you have your spring isolators configured.
Old 11-17-2008, 09:38 PM   #11
YarisSedan
Hmm looks like mine are installed right =)
One thing i noticed though is they are not vertically strait it looks like. Kinda like a half moon bend in them. But i am sure i had them installed facing together the same way as the oem ones when i took them out. ANd put the spring insolators on the same way.
Is this normal orsomething i should be concerned about.
Old 11-17-2008, 11:00 PM   #12
largeorangefont
Break'em off some.
As long as they are on the spring perches.. there is nothing to worry about.
Old 11-17-2008, 11:12 PM   #13
Yoda
Yoda's Avatar
dont worry if its installed wrong but if will easy your mine you can jack you car up again and do it all over...i kno i wont forget that lol
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 08:25 PM
Installed TRD Quickshifter...thumbs up! facebreaker1212 Performance Modifications 13 11-04-2008 11:20 AM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
