Old 08-23-2006, 04:45 PM   #19
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
600 rms, damnnnnnnnnnnn
JWU '09 Baking and Pastry
MacMaster761 is offline   Reply With Quote
Old 08-23-2006, 04:51 PM   #20
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Nice sub.
I put cheap Volfenhag 12's in my hatch, if that sub works at least as good as the ones I got (prob better) itll be one loud hatch. I notice the panel above the hatch on the exterior rattles with the subs going.
mikeukrainetz is offline   Reply With Quote
Old 08-23-2006, 04:54 PM   #21
seriousfun
Drives: 2007 Yaris Liftback Black
I put a Kenwood KSC-SW1 under the passenger seat. 6.5" woofer with a 6.5" passive radiator, 100-some watts claimed, variable crossover. I may add an amp and replacement speakers sometime.
I work with audio every day, and I am extremely critical about sound. Since I have no plans to put a reference-quality system in the Yaris, my needs were met - extending the clean low-end response of the existing system while removing some strain from the main amps and speakers. I didn't want to take up an inch of space in the liftback, and this thing fit fine.
seriousfun is offline   Reply With Quote
Old 08-23-2006, 05:15 PM   #22
mikeukrainetz
Does the depth of this setup effect the operation of the passenger seat?
Old 08-23-2006, 05:43 PM   #23
SEaton
SEaton's Avatar
if you are serious about bass please dont get a bazooka tube
2007 Liftback in 4-5 weeks!
SEaton is offline   Reply With Quote
Old 08-23-2006, 06:47 PM   #24
spacemanoeuvres
spase peepole
spacemanoeuvres's Avatar
Drives: BLAZING BLUE Liftback 5 Speed
why not...?
we am spase peepole
spacemanoeuvres is offline   Reply With Quote
Old 08-23-2006, 09:42 PM   #25
ChinoCharles
Drives: LB
Reasons why not to get a Bazooka tube...
Single voice coil (booo)
200W RMS power handling (weak)
Size (huge enclosure for one 10)
Infinity basslink... same wattage, a little more money, but no need for an amp (I saw one of these in person at a Best Buy and almost left with it... they're awesome)
Reasons why to get one...
Cheap (as hell!)
Enclosure will lessen body vibration
Probably plenty of bass for a hatchback for MOST people
Old 08-24-2006, 12:24 AM   #26
johnnyfive
johnnyfive's Avatar
since this is what is going in my car thread now....http://www.low-hz.com/commerce/catal...products_id=28 is going in custom fiberglass behind the wheelwell, and running 1k watts rms...
johnnyfive is offline   Reply With Quote
Old 08-24-2006, 01:44 AM   #27
ChinoCharles
Drives: LB
Umm... wow. That is going to be amazing. Fiberglass looks super clean when done really well.
Old 08-24-2006, 03:25 AM   #28
SEaton
SEaton's Avatar
Cheap (as hell!)
Like I said, if you are serious about the bass, stay away. If you don't believe me and C.C. go listen to them for yourself. Get yourself a nice 10" with a strong amp and the dif will be incredible
Old 08-24-2006, 06:37 AM   #29
spacemanoeuvres
spase peepole
Reasons why to get one (Bazooka Tube)...
Cheap (as hell!)
Exactly why I bought/kept mine
But I understand what you guys/gals are saying. If you're an audiophile then the tube just ain't up to snuff.
Thanks for the info
we am spase peepole
Old 08-24-2006, 01:13 PM   #30
DJ_Trizzak
DJ_Trizzak's Avatar
Drives: Yaris 07 Auto CE -Blazin Blue
myspace.com/djtrizzak | epik.ca | track1.ca |
DJ_Trizzak is offline   Reply With Quote
Old 08-24-2006, 01:47 PM   #31
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Great setup DJ_Trizzak, but you still lost around 40% of entire your trunk space.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-24-2006, 02:58 PM   #32
DJ_Trizzak
DJ_Trizzak's Avatar
thanks - lols ya I know - I was going to get a custom/fiber glass 2 10" in the back seats near the speakers/cup holders - but it would cost alot of $ $ - so I decided to stick with a basic set up - but I might go with the custom fiber glass thing later on
Old 08-24-2006, 06:05 PM   #33
Fred2006
Fred2006's Avatar
Drives: Yaris 06
Nothing sounds greater than a Big Box !! If you want great sound you don't care about the space you loose!!
http://fred2006.monchar.com/
Fred2006 is offline   Reply With Quote
Old 08-25-2006, 04:27 PM   #34
seriousfun
The Kenwood? My passenger seat works perfectly after installing this - no problem.
And for those who question this or other compact subwoofers, no, this won't play 85 dB SPL at 20 Hz, but it allows my system to play a little deeper and a little cleaner - a great investment IMO. Same goes for Bazookas; they're not bad for the money or the space (round tube, square box, etc., has no effect on sound), but their limitations are from their driver and amp quality. When I can replace the door speakers, I expect that the mids and highs will be equally improved.
Old 08-25-2006, 09:39 PM   #35
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Originally Posted by echo_hrs
If you only want a bit of thump, Rather than a compact sub, why not put a good set of components up front, and some serious mid-bass drivers in the rear...I am half way there, with the components up front, and already find there's enough bass response...
Cheers
This is a very good suggestion for a hatchback (or any vehicle for that matter) that is tight on space, such as our beloved Yarii.
A set of high quality component reference speakers up front would emphasize bass, while a set of component speakers in the rear would balance the bass with appropriate mid and highs.
It's optional whether to use components both front and rear, but if you are after perfection, I say go for it
For me, I will begin with a pair of components up front and then experiment with 2/3-ways in the rear to determine if components should also sit in the rear.
Throw in a shallow mount subwoofer like the thread author has suggested, and you are good to go.
Oh yeah, don't forget to get a HU with at least 2 pre outs, PREFERABLY three pre outs.
ALL YOUR SPEAKERS SHOULD RUN ON AMP POWER!
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-25-2006, 09:47 PM   #36
grimez
grimez's Avatar
Drives: 2007 Yaris
I have always wondered if there wouldn't be room between the front two seats where the arm rest is, maybe throw in a slim profile 8 incher. Brace it up, maybe get a custom molding for it. I think one smaller sub, 8 or 10 inches would be more than enough for a car this size. Of course, power it with an amp.
grimez is offline   Reply With Quote
Kenwood KSC-SW1 Powered Subwoofer seriousfun In Car Entertainment + Electronics (audio / video / alarm) 11 04-02-2007 02:44 PM
