Old 08-22-2006, 03:29 PM   #1
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Subwoofer suggestion for liftback owners
I saw some people who install subwoofers into liftback and lost 50% to 100% of trunk space. But these suggestion may also be interesting for sedan owner who wan't loose any carrying space in the trunk!
I have two great subwoofers suggestions for people who want great bass response and who is concerned about trunk space. I test one of these products and the other one as been tested by one of my good friends.
Suggestion #1 : BLAUPUNKT ODw1000HP
- Size : 10"
- Type : Single Voice Coil
- Power Continuous (RMS) : 200 watts
- Power Peak (MAX) : 600 watts
- Sensitivity (dB 2.83V / 1m) : 90 db
- Frequency Response : 20 - 200 hz
- Magnet Weight : 40 oz
- Cone Material : Aluminium & Foam
- Surround Material : Foam
- Mounting Depth : ONLY 2 INCHES !!
- Enclosure recommanded : ONLY 0.4 SQ-FT SEALLED !!
This subwoofer is designed especialy to be installed in tailgates, rear decks, just about anywhere! You may even install it "free to air" (no need of a box) but it's still better to use sealled enclosure. My friend install one of these into a Mazda Miata (no trunk space), in a "free to air" setup and it play real nice. I had one of these two years ago and I like it very much. I use it into a real real small sealled enclosure (12in x 12in x 6in) and it play REALLY nice. This subwoofer play loud but really clear. For liftback owner, you may even consider to install in directly into the hatchback cover lid!! It's only 10" wide, so you can also install some 6.5" speakers on both side of the subwoofer. What a nice setup!!
Suggestion #2 : CLARION PFW1051
- Size : 10"
- Power Continuous (RMS) : 300 watts
- Cone Material : Kevlar/Paper Composite
- Surround Material : Co-polymer Composite
- Mounting Depth : 3 INCHES
This is also a great product. I'm not sure about enclosure size required, but it's probably very small like the Blaupunkt. My friend test this product and it was very nice too. Just a little bigger mounting depth however.
Hope this suggestions will help some people here.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-22-2006, 04:19 PM   #2
Sérgio Barros
Sérgio Barros's Avatar
Drives: Yaris D4-D
Who search a good one to subwoofer and that it needs a pretty cash. This is my choice: Diamond D308
Mica-filled poly Driver and Ferrite Magnet
Type: Dual voice coil
Power Handling NOM/MAX: 200/400 watts
Sensitivity (2.83V/1m): 83 dB SPL
Freq. Response: 30-500
Mounting Depth/Diameter: 4.1 in. / 7.4 in.
But it costs about 180€
For more information: http://www.diamondaudio.com
http://www.yaristeam.pt.vu
Sérgio Barros is offline   Reply With Quote
Old 08-22-2006, 08:04 PM   #3
SimmZ
That's a great suggestion too.
But the reason why I start that thread to talk about these Blaupunkt and Clarion models it's because they are specially designed for very small space like a hatchback trunk. I saw many audio setup in liftback on this site and maybe peoples aren't knowing that special subwoofers like that exist.
They aren't the most powerfull and best sounding subwoofers on the market, but they sound real good and they are the smallest subs for sure!
Old 08-22-2006, 08:21 PM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Try Bazooka tubes or something like that. I know someone posted in an earlier forum that theey had one in their car.
Old 08-22-2006, 09:09 PM   #5
spacemanoeuvres
spase peepole
spacemanoeuvres's Avatar
Drives: BLAZING BLUE Liftback 5 Speed
werd
http://www.yarisworld.com/forums/showthread.php?t=785
Ripped from my old paseo because I couldn't afford to get anything new
It sounds good but takes up a fair amount of space which is kind of annoying. For example, I always have to take my girl's car grocery shopping because a weeks worth of stuffs won't fit in with that dang tube!
If I had money I'd look at other options (above) but the tube works a'okay for now...
we am spase peepole
spacemanoeuvres is offline   Reply With Quote
Old 08-22-2006, 09:26 PM   #6
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
here is another subwoofer that will fit into a tight space...
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
hahahaha good luck guys
JWU '09 Baking and Pastry
MacMaster761 is offline   Reply With Quote
Old 08-22-2006, 09:53 PM   #7
plushDJ
Drives: 2007 3 dr manual
try the pioneer flat subs, I've heard a couple shops recommend them around here for tight spaces
plushDJ is offline   Reply With Quote
Old 08-23-2006, 01:07 AM   #8
johnnyfive
johnnyfive's Avatar
lol...11 & 1/2" mounting depth, 18" square..not exactly for tight spaces...but that is a good price for a 18" solo X :)
but here is a real good one for you guys with the hatch, you can fit a 6.5" in your rear, correct?
http://www.edesignaudio.com/product....pid=32&cur=USD
throw one of those in each of the rear stock locations, and put a lowpass crossover on them, set at about 80 Hz. and get a nice set of components for the front, and ill bet you have a real nice setup :)
Old 08-23-2006, 03:00 AM   #9
Sérgio Barros
Drives: Yaris D4-D
I have to subwoofer amplified of the Pioneer and it he is so small that he fits underneath of the bank of the front.
It has a command with phase and frenquência, volume control.
Subwoofer has 8" and has incorporated amplifier. Tem 200watts of maximum power.
Its price in new is of 175€
Also you have hipotese to take off the tire substitute and to place subwoofer there.
Old 08-23-2006, 03:59 AM   #10
JustAnotherAsian
now in HD
Drives: not yaris!
Send a message via AIM to JustAnotherAsian
heck, shove in a 200w amp in one of the supposidly large cavities around the trunk area behind the panels, or under a seat, and you've got one stealthy setup.
JustAnotherAsian is offline   Reply With Quote
Old 08-23-2006, 06:28 AM   #11
SimmZ
There's another great product for hatch... but this one is real expensive.
INFINITY BASSLINK II
MSRP U.S. $: 424.95
Power Output: 250 Watts
Frequency Response: 20Hz – 320Hz
Variable Bass EQ: +3dB to -6dB at 45Hz
Variable Electronic Crossover:
Old 08-23-2006, 06:32 AM   #12
SimmZ
I just take a look on Pioneer website and this product is not available to north america market.
Old 08-23-2006, 06:38 AM   #13
SimmZ
But Pioneer carry some new low-profile subwoofers for 2006. I never try this product, but they seem to be great. Blaupunkt still carry the lower profile subwoofer with 2" mounting depth. Pionner is exactly the same size than Clarion.
PIONEER TS-SW2541D
Watts MAX. Music Power : 1000 Watts
Watts Nominal Power Handling : 250 Watts
Frequency Response : 20 ~ 1,000Hz
Sensitivity : 87dB
Ohm Rating : 4
Recommended Enclosure : ONLY 0.35 ~ 0.7 Cubic Feet
Dimensions : 11-1/8" x 3-1/2"
Mounting Depth : ONLY 3"
Old 08-23-2006, 07:02 AM   #14
MacMaster761
Five-Star General
but seriously i just bought this...
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
cant wait till it comes, should fit nicely right in the back left of the trunk
Old 08-23-2006, 08:29 AM   #15
SimmZ
Look like a great product! Size is not too bad... 14" W x 13-1/4" H x 14-7/8" D
Old 08-23-2006, 10:59 AM   #16
weeze-dog
Drives: 2002 Ford Focus ZX3
I wonder if there is a 8" or 10" flat sub solution that would fit under the front seat? Maybe have the sub under one seat, and the amp under the other?
How much room is under the front seats?
You might have to remove the seat to get it in there, but once it is in, should be ok.
That would be great so that it doesn't take up space in the hatch, and it would be easier to wire. Space under the seats is completely unused.
weeze-dog is offline   Reply With Quote
Old 08-23-2006, 12:59 PM   #17
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I think youd only get away with an amp (1.5" - 2.5") under the seats, otherwise youll end up running into all the existing wiring and brackets and then forget about moving the seats (or forget and slide the seats into whatever you have under them... lol)
mikeukrainetz is offline   Reply With Quote
Old 08-23-2006, 02:50 PM   #18
ChinoCharles
Drives: LB
I'll be putting this sucker in my liftback.
Carbon fiber/kevlar cone. 3000 watts peak. I'm going to put 600 RMS to this bad 10" and see what happens. They're supposed to be smooth like butter.
Kenwood KSC-SW1 Powered Subwoofer seriousfun In Car Entertainment + Electronics (audio / video / alarm) 11 04-02-2007 02:44 PM
