Old 01-13-2009, 08:45 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
err.. CAI filter rubs on splashguard...
well, I was hoping I was crazy, but on a hard right turn, I can hear the drivers side tire rubbing on the splashguard, and when I looked, the splashguard is pushed out by the intake filter. 185/60/15 winter tread, shouldnt do that.
before I get aggrivated and throw my stock box back in, has anyone else had this issue and is it as simple as bending the bracket that bolts up where the old box sits?
noticing the position of the outlined bracket above, mine is not bent like that, it is at a 90 degree angle to the intake, I just wanted to ask before I took the bumper of again.
thanks for putting up the noobish questions
EDIT: Just noting that this is not my intake, but the piping is the same..
Old 01-13-2009, 09:56 PM   #2
auxmike
auxmike's Avatar
Ditch it and get the AFE rig;
Old 01-14-2009, 10:31 AM   #3
AlexNet0
AlexNet0's Avatar
haha, if only my wallet agreed with you, I would have gotten it before.
Old 01-15-2009, 02:48 AM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
My AEM intake rubbed on the fender well plastic and rubbed a hole though the grey paint on the intake.
Old 01-15-2009, 07:58 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
Welcome to the world of aftermarket auto parts.
They usually almost fit.
Old 01-15-2009, 08:02 AM   #6
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
If it's that large of a concern (which I assume it is because of you posting about it) then you could remove around an inch from either end of the tube to free up some space, or look into getting a smaller filter for the end.
Alternatively as well if you don't want to remove some yourself you could take it to a local machine shop and have it done. I can't see if being anymore then 20-30 for the work.
Old 01-15-2009, 07:39 PM   #7
AlexNet0
AlexNet0's Avatar
lol
I think If I just bend that bracket about an inch it will fit.
I just wanted an opinion before I take the bumper back off, as I am installing the 1zz throttle body this weekend, Ill just play with it then.
If I remove any length from the pipe, I believe it will rub worse, as it is only the filter that rubs, but thanks for the advise.
Old 01-16-2009, 02:25 AM   #8
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
Keep in mind that with the 1zz TB you'll need a silicon reducer coupling. Something like in the picture below is what you're looking for.
Old 01-16-2009, 02:22 PM   #9
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
smaller filter may help as well.try to compare it to a Ingen filter,as mine was small and has a lot of room.
Old 01-16-2009, 06:41 PM   #10
auxmike
auxmike's Avatar
Forgive me for hijacking a bit, but the 1zz is from the Corolla correct?
Has this TB been installed by someone yet and been proven to function correctly and does it really produce extra HP without enlarging the intake?
Old 01-16-2009, 09:16 PM   #11
AlexNet0
AlexNet0's Avatar
Yeah its from an '06 corolla and I have a coupler, it looks to be the exact one in that picture actually, lol.
I'm not sure if anyone has gotten this particular one to work or not, but I know with the matrix TB people have had it rev 3k at cold idle, but Im going to play with it till it works or I get tired of fighting with it, whichever comes first.
Like many other people, I have no access whatsoever that I know of to a dyno, so I wouldnt be able to tell you any number gains, just what it feels like combined with the cold air intake.
Anyone here in Maine (yah right..) willing to give a free (or really cheap) before and after dyno with this throttle body install?
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
FS: BNIB Bomz CAI w/ Simota Filter Split Items for Sale by private party 15 01-17-2009 03:09 PM
FS AEM CAI w/dry flow instead of oil filter superfly78209 Items for Sale by private party 24 12-26-2008 10:43 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
