Old 01-08-2009, 12:46 AM   #37
gid
the SEVERE GEAR is GL-5 and not safe for synchros , could make for difficult shifting and damage internal parts . The MTG is fine , states that here under PRODUCT DESCIPTION www.amsoil.com/storefront/mtg.aspx . Mentions TOYOTA as well .
Old 01-08-2009, 08:37 AM   #38
1stToyota
1stToyota's Avatar
I think Toyota says GL-4 and GL-5 are both okay for their transaxle, but it just makes sense to use the GL-4 that's designed for transaxles/transmissions with their soft metals and leave the GL-5 for the differentials. I know that the expensive LubroMoly GL-5 75W-90 (made in Germany) didn't do much to improve my shifts.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 01-08-2009, 09:09 AM   #39
Chupacabra
Drives: 2009 Yaris liftback
I think I'd stick with the GL-4 as well.
Chupacabra is offline   Reply With Quote
Old 01-08-2009, 12:55 PM   #40
gid
used MOBIL 1 ( 75w-90 , GL-5 ) in the 2000 PRIZM ( Corolla ) with a speed manual which is similiar to that of the YARIS and threw of the synchros making for grinding when shifting to different gears , downshifting , and the clunk / harder engagement ( grinding ) into reverse worse . When replaced with the REDLINE MT-90 ( GL-4 ) all that disappeared . As for when using the MOBIL 1 synthetic tranny fluid for the power steering in the PRIZM ( Corolla ) it worked wonders . Removed the old P.S. fluid after car sat overnight to withdraw and refill fluid at COLD mark of resorvoir with a animal medicine dispenser ( oral syringe : http://www.drsfostersmith.com/produc...cfm?pcatid=836 ) with a clear plastic air hose ( air pump for fish tank ) attached to syringe ( slips over end ) and drawed out as much of the old / mixed A.T. fluid as possible over period of time until most of the MOBIL 1 A.T.F was gone . That way it would clean and replenish with new fluid over time . The amazing part is that when the regular P.S. fluid in the power steering resorvoir ran hot it would read at or a bit over the HOT mark . When applied the MOBIL 1 synthetic A.T. fluid it read a little over halfway point , COLD mark , when hot ( less friction = less heat = less expansion of fluid ) . AMAZING . NO leaks ( checked often ) . The steering became more responsive ( like that of electric power steering ) and with less effort at slow speeds ( inertia ) . When turning the wheels at a standstill there was no squealing as well . I think it may have helped with gas mileage due to less resistance in turning ( less gas applied to turn , coast ) . If you look in YARIS owners manual it states that one of the benefits of electric steering is for fuel economy . If not mentioned in YARIS owners manual , it did state it in our '07 PRIUS owners manual that was traded in for '08 YARIS sedan . So , if have an older car with A.T. fluid for power steering I highly suggest the MOBIL 1 synthetic A.T.F. ( or other ) for use . I think you'll be quite pleased in the steering performance .
Old 01-08-2009, 01:35 PM   #41
gid
during this time of using MT-90 and MOBIL1 A.T.F. for power steering the PRIZM got a little over 43 miles per gallon . The conditions were : 70% hwy. / 30% city ( speeds up to 70 m.p.h ) , 2 people 90% of time , hot and humid , Tire Pressue : 34 P.S.I. ( Cooper Trendsetter SE ) , GULF 93 octane , and a dose of CHEVRON Techron . The motor oil was regular PENNZOIL 5w-30 . The miles were from looking at '08 YARIS and COROLLAs . The gas mileage that fill is very close to both our '08 YARIS ( automatic sedan and 5 speed manual L.B. ) for best fuel economy . They're best so far has been a little over 44 m.p.g.. Miss that car . Traded in for the '08 Liftback with 5 speed manual . The clutch was easier in that too .
Old 01-08-2009, 04:08 PM   #42
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
So Redline MT-90 is the best for tranny, better than AMSOIL?
Old 01-08-2009, 04:29 PM   #43
gid
, haven't tried it yet for a GL-4 .
Old 01-09-2009, 10:42 AM   #44
1stToyota
1stToyota's Avatar
I'd say the MT-90 and Amsoil's GL-4 75W-90 are both close and very good, probably both are better than my Pennzoil GL-4 75W-90, but I wouldn't care to breakup the theme that I got going on.
2008 Scion xD
Old 01-09-2009, 01:27 PM   #45
gid
PENNZOIL now has a GL-4 synthetic gear oil , http://www.pzlqs.com/Tech/Pdsheet/Do...E75W90GL-4.PDF and http://www.pennzoil.com//products/ge...#SyntheticGear , wonder if this is as good as their PLATINUM motor oil that gets very good U.O.A.s at www.bobistheoilguy.com . May have to give this a try in the future . Should cost less than AMSOIL or REDLINE , may be difficult to find . Sorry to break the mold . Couldn't resist .
Old 01-09-2009, 02:04 PM   #46
1stToyota
1stToyota's Avatar
I discovered it was hard to find. Had to special order mine from Napa. It's in my sig but LubroMoly is what's actually still in my transaxle. I'll switch it out next week. I don't know the cost yet. I didn't ask.
2008 Scion xD
Old 01-09-2009, 02:27 PM   #47
gid
let us know how the PENNZOIL GL-4 synthetic works out for you . THANKS 'n' GOOD LUCK .
Old 01-14-2009, 10:46 AM   #48
yuri2002
Drives: Yaris HB
When is the appropriate time to change manaul transmission fluid. I have 53K miles and own the car about 2 years now.
yuri2002 is online now   Reply With Quote
Old 01-14-2009, 02:54 PM   #49
gid
now be fine .
Old 01-14-2009, 03:56 PM   #50
1stToyota
1stToyota's Avatar
Still waiting on Napa to give me a call when the Pennzoil comes in...they said 1 week, which I think would have been the 13th.
2008 Scion xD
Old 01-14-2009, 04:13 PM   #51
WolfWings
WolfWings's Avatar
Originally Posted by nsmitchell View Post
It must be the new manual trannys, but in all the manuals I've ever done, I just used a normal motor oil like Mobil-1 10W-30. They all shifted like a dream! 75W-90 is some thick stuff. I wonder why it needs to be so thick?
Hell, old 3rd-gen Civic manual transmissions recommended 30W engine oil in the transmission, and the engine if you lived in temperate and mild climates. Made it insanely-cheap to just change all the fluids every oil change, since 30W is just about bottom-barrel for price.
Old 01-14-2009, 08:51 PM   #52
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Now that where talking about Tranny Oil I got an issue with mine i got some MT-90 and wow great stuff all around it's so smooth! the only thing is that I get a slight grinding sound when I rev hard really hard and shift to 3RD gear I have a NST SSK and TWM short shifter can I be shifting to fast for synchros?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-14-2009, 11:17 PM   #53
gid
could be the combo . No issue here , no upgrades tho .
Old 01-14-2009, 11:22 PM   #54
gid
waiting is .
give us the scoop once it's been installed . May want to give it a try myself over time . Keep seeing very good U.O.A.s for the PLATINUM motor oil at B.I.T.O.G.. Would think their synthetic gear oil be a good performer too . Hang in there .
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 06:09 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
