Old 09-05-2006, 01:11 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Bucket seat install
Hi Guys
I saw a thread on a bucket seat install , can anyone tell me if the seat rails just bolt off the original seats or if its welded on , it seems to just bolt off , and has anybody else installed bucket seats , cause i wanna put buckets seats in my yaris , but wanna know if there is any electronic failures ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 09-05-2006, 02:37 PM   #2
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
The one thing youll probably have to fab up is the seat sensors on the passenger side for the airbags.
mikeukrainetz is offline   Reply With Quote
Old 09-05-2006, 04:22 PM   #3
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
The seats are attached to the rails by eight bolts. Getting around the electronics issue on the driver's side is easy, you just detached the wiring harness from the stock seat. The passenger side may be a bit trickier because it has a weight sensor as well as a belt sensor, but it's probably just a matter of using the proper resistor value across a couple pins or something.
Idjiit is offline   Reply With Quote
Old 09-05-2006, 04:24 PM   #4
Idjiit
5 Stars, Bitches
Here's the original thread concerning removing the seat:
http://www.yarisworld.com/forums/sho...ghlight=sparco
Here's the thread from my install:
Old 09-06-2006, 08:26 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
how did u get past the passenger side airbag and sensor problem
JDMtuner
www.jdmtuner.co.za
Old 09-06-2006, 08:49 AM   #6
Idjiit
5 Stars, Bitches
By not installing a passenger's side race seat.
Old 09-06-2006, 05:10 PM   #7
dngz
dngz's Avatar
Drives: black yaris sedan
therez gotta be a way to get the passenger side airbags working with racing seats!!!
dngz is offline   Reply With Quote
Old 09-07-2006, 02:01 PM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
maby by trying to install a sensor of some sort , ultimately the buzzer tells the person to put it on , but so long as the seatbelt is cliped in , it will be activated.
JDMtuner
www.jdmtuner.co.za
Old 09-07-2006, 03:43 PM   #9
dngz
dngz's Avatar
or is there a way to have the passenger airbag always on??? im just scared that if i change it, the passenger airbag will become useless...
Old 12-07-2012, 02:04 PM   #10
veather
Drives: Yaris 2010
What seats could fit????
Dont know much about the yaris other than glad has good gas mileage and sad the passenger seat is terrible!!!! Please tell me what kind of seat would fit , the measurements would be what I need to find!!? please help!!!
veather is offline   Reply With Quote
Old 12-08-2012, 03:46 PM   #11
nookandcrannycar
Holy thread resurrection! ()
Old 12-08-2012, 06:23 PM   #12
TOLMACH
Drives: soarer
just width
race seats usually have shallow bottoms, you;ll need some sort of height adjustment between the brackets and seats (may be the rails only will suffice)
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
60/40 rear seat in LB - anyone install one? wilco Cosmetic Modifications (Exterior/Interior) 0 08-20-2006 06:42 PM
back seat KSIbucky General Yaris / Vitz Discussion 10 05-30-2006 12:54 PM
