AKA Samurai Racer
Bucket seat install
Hi Guys
I saw a thread on a bucket seat install , can anyone tell me if the seat rails just bolt off the original seats or if its welded on , it seems to just bolt off , and has anybody else installed bucket seats , cause i wanna put buckets seats in my yaris , but wanna know if there is any electronic failures ? |
The one thing youll probably have to fab up is the seat sensors on the passenger side for the airbags.
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback Join Date: Mar 2006
The seats are attached to the rails by eight bolts. Getting around the electronics issue on the driver's side is easy, you just detached the wiring harness from the stock seat. The passenger side may be a bit trickier because it has a weight sensor as well as a belt sensor, but it's probably just a matter of using the proper resistor value across a couple pins or something.
5 Stars, Bitches
Here's the original thread concerning removing the seat:
http://www.yarisworld.com/forums/sho...ghlight=sparco Here's the thread from my install: http://www.yarisworld.com/forums/sho...ghlight=sparco |
AKA Samurai Racer
how did u get past the passenger side airbag and sensor problem
5 Stars, Bitches
By not installing a passenger's side race seat.
therez gotta be a way to get the passenger side airbags working with racing seats!!!
AKA Samurai Racer
maby by trying to install a sensor of some sort , ultimately the buzzer tells the person to put it on , but so long as the seatbelt is cliped in , it will be activated.
or is there a way to have the passenger airbag always on??? im just scared that if i change it, the passenger airbag will become useless...
Drives: Yaris 2010 Join Date: Dec 2012
What seats could fit????
Dont know much about the yaris other than glad has good gas mileage and sad the passenger seat is terrible!!!! Please tell me what kind of seat would fit , the measurements would be what I need to find!!? please help!!!
Holy thread resurrection! ( )
#12 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
race seats usually have shallow bottoms, you;ll need some sort of height adjustment between the brackets and seats (may be the rails only will suffice) |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 08:37 AM |
| 60/40 rear seat in LB - anyone install one? | wilco | Cosmetic Modifications (Exterior/Interior) | 0 | 08-20-2006 06:42 PM |
| back seat | KSIbucky | General Yaris / Vitz Discussion | 10 | 05-30-2006 12:54 PM |
