Old 02-13-2009, 05:11 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Upgraded Spark Plugs For Boost
I'm installing the blitz supercharger in less than 2 weeks, what spark plugs i should upgrade to?
I know nothing about spark plugs other than they ignite the compressed gas and air in the piston chamber. unless u have a diesel engine and u dont have spark plugs.
Old 02-13-2009, 05:19 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
no clue but im hitting you up on xbox live..... andy
Old 02-13-2009, 05:34 PM   #3
whooppee777
is this rocklandtoyota/IMPO andy or are you another blue yaris in NY whose name is Andy?
Old 02-13-2009, 06:20 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Just look at the heat range on the stock plug and go with a set of spark plugs that are 1 step colder
Old 02-13-2009, 07:49 PM   #5
whooppee777
and the stock spark plug heat range would be...........
Old 02-13-2009, 09:05 PM   #6
I will email you your installation manual and wiring guides, whooppee -- it will answer these questions....and give you something to do for the next two weeks...
Old 02-14-2009, 09:05 AM   #7
whooppee777
u actually e-mailed me one, and then my friend had it laminated and gave it a spiral bound spine. so im guessing the installation manual tells me what i should get?
Old 02-14-2009, 10:16 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
i switched from iridium to plain ol $1.99 copper plugs, 2 steps colder. no need to throw away $$ on iridium plugs..
Old 02-14-2009, 10:21 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by camelll View Post
You can do that as well tamago, I just went with what was recommended by the manufacturer.
i'm in a different world too, with a lot more fuel being dumped into the engine.. i'll be switching back to Denso IK22's shortly, once i feel my a/f ratios are consistantly where i want them.
Old 02-14-2009, 01:53 PM   #10
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
That is a common practice from people with high power turbo cars (Supras , Skylines)
They usually use cheap copper plugs for the tunning process as the usually will kill a bunch of plugs on their long dyno sessions. So there is no point on throwing expensive plugs in. The copper ones will perform almost the same as the higher priced IRIDIUMS... they just won't last long.
Once they are all set with their tune... they just replace the copper plugs with the Iridiums.
Another common advice is:
For forced induction applications, use either copper plugs or Iridium plugs. But nothing in between like platinum.
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 11:08 AM
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 04:05 PM
Read My Spark Plugs Yaris T-Sport Forced Induction Forum 5 01-21-2009 11:56 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
Bujias?¿ Normales o otras? Fer.pa Central and South America 12 07-13-2007 03:46 PM
