#19 | |
hey, everyone, Loren's here! now you can believe what i said waaay back in post #2 lol
#20 | |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
(as is typical of me, I said the same thing, just used a helluva lot more words) |
#21 | |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Mis-shift would also be another possibility but he never mentioned if it was auto or manual. |
#22 |
Usually when this happens the computer records the live data. It will record engine rpm and vehicle speed in freeze frame. Dealer can see how fast you were going and what rpms. If you are above redline and shows you going 100mph and engine coolant temeprature shows the vehicle isnt even warmed up then dealer is going to say sorry bozo.
I mean usual way to bend valves is when you have the piston colliding with the valves due to incorrect timing or in most cases cars that run timing belts and the belt brakes. I have seen a mechanic install a timing chain wrong once engine ran for a few seconds and you hear this clack clack clack. removed the cylinder head and the piston snapped the valve off turned it upside down and it punctured a hole through the piston head. |
#23 |
What?
Since this car is at a Toyota dealer... do the Toyota diagnostic tools have the ability to look at things like "max RPM" and such? I would think a missed shift situation would show up as a pretty serious RPM spike. Max speed might be in there, too... 70 mph?
#24 |
What?
Haha! We must have been telepathically linked.
#25 | |
3-4-3 :( didn't take too much speed
#26 |
What?
3rd gear is good to about 80 mph, so you'd have to be going considerably faster than that in 4th to get into trouble by going back down to 3rd, wouldn't you? Dunno how sensitive this engine is, I guess if it's particularly fragile, maybe it doesn't take much.
Or is it the immediate acceleration of the engine to 6000 rpm rather than high rpm itself that's causing it to break? |
#27 |
FYI: its a manual TC.......
#28 | |
and yes, i was going considerably faster than i should have been.. it snapped the crankshaft pulley's rollpin (thankfully no harm was done to the crankshaft) and slightly bent at least one set of valves..
| Amp with Stock Head? | Boy Blue | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 06-11-2011 11:53 AM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
| Does the non integrated head unit do any processing? | ponieswhee | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 05-07-2007 09:00 PM |
| human head in coffee beans | wushumasterku | Off-topic / Other Cars / Everything else Discussions | 8 | 04-19-2006 11:39 PM |
