Old 06-06-2007, 09:10 PM   #1
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
Amp with Stock Head?
I am thinking about adding a sub and replacing the speakers but i don't want to add an aftermarket head, Is it possible to amp the stock head? would splitting from the current speaker wires to the amp then back to the speakers work? I have a sony head unit but all the kits available in canada for the dash look like crap.
Boy Blue is offline   Reply With Quote
Old 06-06-2007, 09:22 PM   #2
BlueFlash
wa do dem
BlueFlash's Avatar
Drives: 2007 blue Lb
you can use a line out to power the subs but to power the component speakers you cant unless you run the signal to the amp and then back to the speakers and you should use an amp for the subs and one for the speakers if you do that just amp the subs useing a line out and replace the speakers it will sound good but not as good as amped speakers with a aftermarket head unit
BlueFlash is offline   Reply With Quote
Old 06-06-2007, 09:33 PM   #3
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
What colour is the line out wire that i will need to tap into?
Old 06-06-2007, 09:43 PM   #4
BlueFlash
wa do dem
BlueFlash's Avatar
well the easy way is just use the back speaker on either side use both negs and pos togather from one speaker brb with pics for you
Old 06-06-2007, 09:57 PM   #5
BlueFlash
wa do dem
BlueFlash's Avatar
see like that
Old 06-06-2007, 09:58 PM   #6
BlueFlash
wa do dem
BlueFlash's Avatar
Old 06-06-2007, 09:59 PM   #7
BlueFlash
wa do dem
BlueFlash's Avatar
Old 06-06-2007, 10:00 PM   #8
BlueFlash
wa do dem
BlueFlash's Avatar
both negs- to brown both pos+ to yellow on the drivers side
Old 06-06-2007, 10:06 PM   #9
Boy Blue
Boy Blue's Avatar
Drives: 3Dr H/B
Awesome, I have a project to work on this weekend. Thanks for your help!
Old 06-07-2007, 10:41 AM   #10
antfeldsch
Drives: yaris
can you show me how to get to the head unit and where to hook up line out converter. Very new to this stuff?
antfeldsch is offline   Reply With Quote
Old 06-07-2007, 01:53 PM   #11
BlueFlash
wa do dem
BlueFlash's Avatar
why when you can just do it in five minutes the way i have it in the pics and it works just as good
Old 06-11-2011, 11:53 AM   #12
mhkritzinger
Drives: 1.8 3dr Yaris TS
How did you guys took the wires from the head unit to the amp and then to the speakers. I am thinking of adding 4 new speakers and a sub with an amp to the stock head unit, since I have a TS and don't want to replace the HU.
mhkritzinger is offline   Reply With Quote
2007 stock head unit dims out antfeldsch In Car Entertainment + Electronics (audio / video / alarm) 1 06-15-2007 09:12 AM
Stock Head Unit + watts naossoan In Car Entertainment + Electronics (audio / video / alarm) 6 05-25-2007 09:00 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
Stock Head Unit from '07 Sedan Venom Items for Sale by private party 5 01-19-2007 08:27 PM
