#19 |
Yeah it's like they said, If you shift to R while moving forward, you will hear a loud crank noise, at this point you should freak out and let go of the shift knob, the box should spit the gear the neutral, then place it in the correct gear. The shift box is designed to spit you to neutral when a gear isn't properly engaged. It has happened to me when I don't pull the stick all the way then I rev and go no where. Re-clutch and engage the correct gear and you're off!
#20 | |
that's some priceless misinformation right there
#21 | ||
there is really no excuse to mistakenly shift into reverse on any automatic cars. |
#22 | |
#23 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Speaking of which, I think I'm starting to get used to the clutch on my Yaris, finally. Pfewww, about time, too! It looks like the key to shifting smoothly in low gears with that car is to give it a little more gas, otherwise it chokes.
#24 | |
![]() Drives: 08 Flint Mica Sedan Join Date: Dec 2008
My dad was furious but never found out why the reverse gear didn't didn't work anymore. |
#25 | |
#26 | |
probably just poor wording on your part but it made it sound like the gearbox automatically put itself back into gear ![]()
#27 | |
| Werid Noise When I throw it into Reverse | LoudYar | General Yaris / Vitz Discussion | 12 | 10-26-2020 04:57 AM |
| reverse gear whine | jonismyname | DIY / Maintenance / Service | 7 | 03-12-2009 01:17 PM |
| Yaris 2007- How to Restart Multimode gear? | ronen | DIY / Maintenance / Service | 1 | 02-21-2009 05:09 PM |
| Decided on synthetic gear oil | caveatipse | Performance Modifications | 4 | 10-01-2007 04:57 PM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
