Old 03-19-2009, 12:24 PM   #55
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
You just flipped it around? I thought you have to rotate it.
Old 03-19-2009, 03:10 PM   #56
IllusionX
Drives: 07 Yaris Sedan Aero
rotate?
when i took it apart, the other plastic just fell out, so i flip it over, and put it back together... i might try it with the yaris.. i'll get back if it works.
but as i saw the last time i took it off.. it seem like it was just a thin film glued on it..
Old 03-19-2009, 04:04 PM   #57
Flipping works the same as rotating with linear polarization.
LCD manufacturers used to just sandwich the polarizing film, so you could just flip it. Now they all seem to glue them (probably because most of what they make are now frameless ones).
Old 03-19-2009, 05:52 PM   #58
Meteorite_Marty
Flipping does nothing on my radio. I had to remove the film (which has adhesive), and turn it 90 degrees.
Btw... I just got my new 17" polarizing sheet from 3Dlens.com. Fast delivery!!!
Tried it up against my radio and it seems the polarizing will be dark enough to invert the display. Will apply it tonight, and post pics.
Old 03-19-2009, 07:03 PM   #59
Sodium Duck
╚══════════RN
Wow - that was fast! Can't wait to see how it looks.
So will your inversion be black background with green letters?
Old 03-19-2009, 07:04 PM   #60
Sodium Duck
╚══════════RN
Oh, and how thick is the material? The one from Edmund Optics was pretty thick, maybe about 10 sheets of paper I'd say. Not very flexible at all.
Old 03-19-2009, 08:17 PM   #61
I've been doing some experimentation with LCDs. I have a reflective one (the black on white type with no backlight) and a transmissive one (black on white with a green backlight, hence black on green).
With the reflective one I can flip the polarizer to invert the characters. With the transmissive one flipping has no effect (I have to rotate the polarizer to invert).
In doing some reading, reflective LCDs use one clear polarizer on the front surface. Transmissive ones use a second on the back.
I took the transmissive one, pulled off the rear film and flipped it. After doing so I could also flip the front and the entire display was inverted and twice as bright as with the rear not flipped and the front rotated.
Old 03-19-2009, 08:40 PM   #62
Sodium Duck
╚══════════RN
And we have the transmissive type for the gas gauge, correct?
Old 03-19-2009, 08:49 PM   #63
Here are some pictures:
Here is the normal mode for the LCD:
Here is the front and rear both flipped:
Here is rear normal, front rotated 90 on side A:
Here is rear normal, front rotated 90 on side B:
Old 03-19-2009, 08:53 PM   #64
Correct - Gas gauge (and the radio display) are both transmissive. Hence the reason that flipping just one doesn't work.
Old 03-19-2009, 09:32 PM   #65
Meteorite_Marty
Black background with WHITE letters. I did a radio LED mod. My entire dash, heater controls, door lock, gear shifter are matched. NO MORE GREEN!!!
Old 03-19-2009, 09:34 PM   #66
Meteorite_Marty
Its a film. Rigid, but as thin as one sheet of paper.
Old 03-19-2009, 10:39 PM   #67
Sodium Duck
╚══════════RN
Scott, you playing with your OBDII port? What are you brewing over there!? =]
Old 03-19-2009, 10:43 PM   #68
That's my home brew ScanGauge. It's not packaged and the LCD is socketed, so it's a good test platform for monkeying with LCDs.
Old 03-19-2009, 10:45 PM   #69
When you put the ES film on your gas gauge, did you notice the effect in the pictures, where when rotated the film works on either side, but one much better than the other?
Old 03-20-2009, 12:32 AM   #70
Sodium Duck
╚══════════RN
I did a test where I just held the film up to the LCD, both sides and both directions, and didn't notice any difference. *shrug* maybe it's just me?
Old 03-20-2009, 12:33 AM   #71
Sodium Duck
╚══════════RN
You know, I still have one more 2" X 2" film... maybe I'll try replacing the back...
Old 03-20-2009, 09:57 AM   #72
Meteorite_Marty
Here are my pictures of my completed test radio deck. I also took some comparison shots with my main radio deck, which I will do later. Test deck is the one with cracked button.
