Old 03-07-2009, 11:59 PM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Inverting an LCD
I've seen a few tutorials on how to do this online, anyone done it?
I'd like to invert the gas gauge.
Old 03-08-2009, 12:14 AM   #2
GeneralDon7
Drives: Yaris Sedan
There was one member on here, who got it done by someone, else, and all they used was a film that you could buy that inverted it, ill post the link if i can find it.
GeneralDon7 is offline   Reply With Quote
Old 03-08-2009, 12:55 AM   #3
Sodium Duck
╚══════════RN
Yes, I believe you can just buy any LCD polarizing film. I've found a few places that sell it, sorta expensive.
Old 03-08-2009, 10:07 AM   #4
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
That's interesting....
wsladaritz is offline   Reply With Quote
Old 03-08-2009, 02:37 PM   #5
Sodium Duck
╚══════════RN
Yea, I found that site last night. I think I may go to the dollar store and buy some calculators to practice on.
Old 03-08-2009, 02:37 PM   #6
Sodium Duck
╚══════════RN
Umm, I'm no electrician. How would I go about reversing the cathode input? Would that be easier or give a better result?
Old 03-08-2009, 03:38 PM   #7
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
contact this person from Scion Life www.garage1217.com he does all this kind of stuf for the Scions and has all the materials you will need and can give you a how to do it as well...he is really cool.
Old 03-08-2009, 04:17 PM   #8
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
i have done that when in was in primary school with a calculator, i was able to take the lens in front of the lcd display and turn it (side facing lcd display goes outside and outside goes inside) and the color was inverted white digits and black background
not sure how the gas gauge is but would probably work too
the_boss is offline   Reply With Quote
Old 03-08-2009, 07:18 PM   #9
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
isn't it factory on some models? i'd like to do it, myself. this and the radio color were the two biggest "cons" in getting the car i did.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 03-08-2009, 08:34 PM   #10
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Where do you get the LCD polarizing film to even take on this job?
Meteorite_Marty is offline   Reply With Quote
Old 03-08-2009, 08:52 PM   #11
When I've inverted LCDs, I bought the film from Edmund Scientific:
http://www.edmundoptics.com/onlineca...productid=1912
Old 03-10-2009, 02:27 PM   #12
Sodium Duck
╚══════════RN
Ha, I just bought a 1$ calculator at Walmart to try it out, very easy to do. I'm going to buy a sheet of polarizing film to do this.
Is there a way to know what the orientation of the film is so I don't need to temporarily plug the gauges back in to the car?
Old 03-10-2009, 02:35 PM   #13
Theoretically, you could use your $1 calculator as a test fixture for the orientation. After removing its film, place the original Yaris film over it, and note the effect, then remove it and rotate the new film over it until you see the opposite effect as the Yaris film.
Old 03-10-2009, 02:39 PM   #14
Sodium Duck
╚══════════RN
Found this on the site you posted before Scott:
How can I tell what the polarization axis is for a linear polarizer?
The axis of a linear polarizer determines the plane of polarization that the polarizer passes. There are two ways of finding the axis of a polarizer. A simple method is to start with a known polarizer with a marked axis. Place both the known and unknown polarizer together and transmit light through them. Rotate the unknown polarizer until no light passes through the pair of polarizers. In this orientation, the unknown polarizer's axis is 90° from the axis of the known polarizer.
If a known polarizer with a marked axis cannot be found, the axis can be found by taking advantage of the Brewster effect. When light reflects at glancing incidence off of a non-metallic surface, the S-polarization is reflected more than the P-polarization. A quick way to do this is to look at the glare off of a tiled floor or another non-metallic surface. Rotate the polarizer until the glare is minimized. In this position, the polarizer is oriented so that the axis is vertical. As an example, sunglasses use polarizers that have the polarization axis vertically oriented.
Old 03-10-2009, 02:41 PM   #15
Sodium Duck
╚══════════RN
I think the 2"X2" sheet there will just almost perfectly fit the LCD btw. I just ran down and did a quick measurement on the car, and it looks like it's just a bit under 2" wide. For 9$ you can't go wrong.
Old 03-10-2009, 02:42 PM   #16
Sodium Duck
╚══════════RN
Or I could take a chance here, lol.
http://www.sciplus.com/singleItem.cf...ogFrom/froogle
Old 03-10-2009, 02:47 PM   #17
Sodium Duck
╚══════════RN
Or they're really big and cheap here.
http://www.3dlens.com/shop/polarizer.php
Old 03-10-2009, 03:03 PM   #18
Sodium Duck
╚══════════RN
Edmunds Optics does not have an adhesive backing on them.
