#109 | |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Backpressure does not create exhaust gas velocity, if the pipe diameter is too big the air moving down the pipe slows down and cools down which in turn makes the air molecules less active slowing down the flow. The reason race cars don't release at the exhaust port is because exhaust velocity actualy help draw air out of the cylinder head, but to get that you need the right diameter and length of pipe to create the exhaust velocity, what you don't want is any back pressure to slow down the flow, You have the right idea just not the right terminology, there are some really good papers on exhaust design and performance done by ASTM I belive, that tell you exactly that.
#110 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Dyno guy now admits that replacement of the fuel pump (like Garm's turbo install) or replacement of the stock injectors is probably in order if the goal is to get more fuel to the engine during boost. Calculating the proper injectors size, using the many online injector calculators, is a little bit daunting but I'll use them all until I can understand the concept and get consistent results. I'd rather understand the science behind the proper selection of injectors rather than just shotgunning any device in and hoping that they do the job adequately.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#111 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
You guys will not be able to solve this by just swapping out parts. You will solve one problem and create 5 more with bigger injectors. |
#112 |
http://www.yarisworld.com/forums/showthread.php?t=15488
this might be worth trying *just* to see what it does to the AFR... forcing the car to be in warmup mode sounds like a very half-assed (quarter-assed?) way of tuning a car, but desperate times can call for desperate measures
#113 | |
#114 |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
Yeah, ScanGauge definitely does not do injector duty cycle. What would? Some type of logger. That would certainly help narrow down some of the issues!
2006 Red Blitzed RS 5-door |
#115 | |
Mr. Clean
http://store.summitracing.com/partde...5&autoview=sku It increases voltage to the fuel pump as boost increases. Seems like it could be a good solution for moderate boost levels. |
#116 |
Interesting. Since it only increases when boost increases, are those intervals too short for the ECU to catch on?
#117 | |
Any mechanical engineers out there?
#118 |
Ive seen the Boost-a-pump used on a buddys Mustang and it works well, if you need to squeeze a bit more out of the fuel pump. If Richard Holdners Intake /exhaust combo made more hp than the supercharger it must be using more fuel to acheive this. I don't think it's the fuel delivery, but maybe the management of the delivery thats causing a lean condition. I wish you pioneers luck to figure this out.
#119 |
The ARK Design MFD has the provision to display injector duty cycle. I'm going to try and wire it up this weekend!
An Air/Water intercooler might be possible with the blitz kit, but it will require some fabrication (probably a lot!). |
#120 |
I believe the Blitz R-Vit can control a/f with additional percentage.
#121 | |
Break'em off some.
You would be better off spending money on a way to tune the car. |
#122 |
What does Open Loop really mean?
I thought that Open Loop meant that the ECU was not making adustments to the engine parameters. Like when you are in DFCO. Today when crusing on the freeway, I switched my ScanGauge to show the OPEN/CLOSED loop state of the engine.
Anytime I went into boost, even slight boost, the ScanGauge showed OPEN Loop. If that is true, what would cause the ignition to retard? This is confusing. I could not repeat this on surface streets and boosting lightly. I'm still working on a new camera mount and will video the gauge cluster and ScanGauge to demonstrate this new mode of operations. Wierd.
#123 | |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
#124 |
Break'em off some.
In open loop the ECU is *probably* not making fueling adjustments, but it depends on what is happening. If there is severe knock or other problems, you will shift to another fueling map, or the ECU will make fueling corrections.
The ECU is always adjusting timing regardless of open or closed loop. Did you reset the ECU and drive the car to see what the timing was on a fresh reset? What is needed here is full Toyota OBD software. That will allow you to watch everything the ECU is doing. Or like I said, we can put my knock light on the car. If you are indeed knocking, first think I would try is one heat range colder plugs. |
#125 |
I have not heard audible evidence of knocking like I did before I filled up with 91 octane. The only reason that I am guessing there is knocking is the ingition timing being retarded. I know others have to add octane boosters to stop their audible knocking.
I'll reset the ECU on Sunday and try the tests suggested.
#126 | |
I am not yet fully familiar how the car calculates ignition advance in normal closed lop mode (apart from retarding it on detecting knock), but it most likely either has a map for it too, or just pegs it to maximum retardation, in which case the open loop operation is pretty much a "safe mode" no matter what. So, if this blitz controller is able to invoke open loop *without* tripping a CEL, it certainly should allow a lot more flexibility! The question is, how does it do it, and how can we emulate this to use with other piggyback systems... *thinking cap goes back on* Gonna add some related musings/manual findings to the other thread
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
